Inputting Letters via Serial Monitor to BS2 ?
Is it possible to input letters via Serial Monitor to BS2? I can not find any reference to this in the Help directory or in any of the topics. I have a working code using numbers. But it would be more user friendly if I could use letters.
Sure, the BS2 can accept letters. There are several ways to do it. Here is an example that responds to individual letters that a user types in at a terminal in response to various options...
SEROUT 16,sbaud,["(L)og (V)iew (Z)oom (O)ffload (N)ewRun (C)lock (P)arams (fF)eed (U)SBkey",CR,REP LF\lfb,">",BELL] SERIN 16,sbaud,timeout,goIfTimeout,[char] ' user choice, add WAIT ("PW") if password required IF char>$60 AND char<$7b THEN char.BIT5=0 ' -> uppercase ix=15 ' this if not in list LOOKDOWN char, ["!$NOLVZCFDPU"],ix ' converts the letter entered by user into a numerical index BRANCH ix,[bulkErase,offloadBackup,newRun,offload,log,view,zoom,Setclock,feed,dump,parameters,USBvDrive] ' selects which subroutine to runI am relatively new to the stamp coding and will need a bit more explanation. I have included a piece of my working code:
I am using a Pololu qik-2s9v1 motor controller. This project is going to add animation to my model RR. The mechanics are already under way.
ENTER ONE OF THE FOLLOWING NUMBERS INTO THE DEBUG SCREEN FOR ONE OF THE FOLLOWING ACTIONS. ' #1 = FORWARD, #2 = REVERSE, #3 = STOP, #4 = TURN RIGHT, #5 = TURN LEFT ' #6 = SLOW FORWARD, #7 = SLOW REVERSE. '*********************************************************************************** Main: DO DEBUGIN SNUM myNum SELECT myNum CASE 1 ' FORWARD M0 M1 IF (myNum = 1) THEN SEROUT 14,32,[170,9,8,127]: SEROUT 14,32,[170,9,12,127] HIGH 0 LOW 1 DEBUG "FORWARD" DEBUG CR CASE 2 ' REVERSE M0 M1 IF (myNum = 2) THEN SEROUT 14,32,[170,9,10,127]: SEROUT 14,32,[170,9,14,127] HIGH 1 LOW 0 DEBUG "REVERSE" DEBUG CR CASE 3 ' STOP M0 M1 IF (myNum = 3) THEN SEROUT 14,32,[170,9,10,0]: SEROUT 14,32,[170,9,14,0] LOW 0 LOW 1 DEBUG "STOP" DEBUG CRNo worries. If you like, you can always edit your previous post with the code.
Just put [co de] right before your program and [/co de] after, but don't use spaces like I did.
I am getting close to getting my code to work.
' {$STAMP BS2} ' {$PBASIC 2.5} ' 2/10/2015 char VAR Byte idx VAR Byte OUTPUT 0 'BICOLOR LED OUTPUT 1 'BICOLOR LED DEBUG CLS, "(F)orward (B)ackward (H)alt ",CR Main: DEBUGIN char IF (char>$40 AND char<$5b) THEN char.BIT5 = 15 ' Letters A - Z Uppercase LOOKDOWN char,["!$BFH"],idx ' Converts the letter entered by user into a numerical index. BRANCH idx,[_Forward, _Backward, _Halt] ' Selects which subroutine to run. END _Forward: HIGH 1 LOW 0 DEBUG "FORWARD" DEBUG CR END _Backward: HIGH 0 LOW 1 DEBUG "BACKWARD" DEBUG CR END _Halt: LOW 0 LOW 0 DEBUG "STOP" DEBUG CR ENDEach of the movement routines end with an "END", which puts the Stamp into a low-power shutdown mode.
I would suggest using GOSUB/RETURN for the movement routines (check the Reference manual or Help in the Stamp IDE).
And welcome to the Forum.
DJ
[size=1]ENTER ONE OF THE FOLLOWING NUMBERS INTO THE DEBUG SCREEN FOR ONE OF THE FOLLOWING ACTIONS. [color=red]' F or f = forward, R or r = reverse, S or s = stop, and so on[/color] ' #1 = FORWARD, #2 = REVERSE, #3 = STOP, #4 = TURN RIGHT, #5 = TURN LEFT ' #6 = SLOW FORWARD, #7 = SLOW REVERSE. '*********************************************************************************** Main: DO DEBUGIN myNum SELECT myNum [color=red]CASE "F","f"[/color] ' FORWARD M0 M1 IF (myNum = 1) THEN SEROUT 14,32,[170,9,8,127]: SEROUT 14,32,[170,9,12,127] HIGH 0 LOW 1 DEBUG "FORWARD" DEBUG CR [color=red]CASE "R","r"[/color] ' REVERSE M0 M1 IF (myNum = 2) THEN SEROUT 14,32,[170,9,10,127]: SEROUT 14,32,[170,9,14,127] HIGH 1 LOW 0 DEBUG "REVERSE" DEBUG CR [color=red]CASE "S","s"[/color] ' STOP M0 M1 IF (myNum = 3) THEN SEROUT 14,32,[170,9,10,0]: SEROUT 14,32,[170,9,14,0] LOW 0 LOW 1 DEBUG "STOP" DEBUG CR[/size]In that scheme, you'll have to come up with single letter alternatives for slow forward and slow backward. Oh, it may not be clear from the Stamp manual, but the instruction
DEBUGIN myNum
receives one byte, an ascii code, from the serial input.
Thanks for all your help! I have dropped the slow speeds for now, may not need them. Here is the code.
How do you put a SOLVED on the thread?
' {$STAMP BS2} ' {$PBASIC 2.5} ' 2/10/2015 myNum VAR Byte 'ENTER ONE OF THE FOLLOWING LETTERS INTO THE DEBUG SCREEN FOR ONE OF THE FOLLOWING ACTIONS. ' F or f = forward, R or r = reverse, S or s = stop. '*********************************************************************************** DO DEBUGIN myNum SELECT myNum CASE "F" ' FORWARD M0 M1 IF (myNum = 1) THEN SEROUT 14,32,[170,9,8,127]: SEROUT 14,32,[170,9,12,127] HIGH 0 LOW 1 DEBUG "FORWARD" DEBUG CR CASE "R" ' REVERSE M0 M1 IF (myNum = 2) THEN SEROUT 14,32,[170,9,10,127]: SEROUT 14,32,[170,9,14,127] HIGH 1 LOW 0 DEBUG "REVERSE" DEBUG CR CASE "S" ' STOP M0 M1 IF (myNum = 3) THEN SEROUT 14,32,[170,9,10,0]: SEROUT 14,32,[170,9,14,0] LOW 0 LOW 1 DEBUG "STOP" DEBUG CR ENDSELECT LOOPEdit your original post in the "advanced" mode. You'll find a selector box toward the top that will have a "solved" option.
