SX-48 Single sided board in Eagle.
LoopyByteloose
Here are a set of SX-48 Eagle files, board and schematic, plus a image PDF and a transparency PDF.
As was done with my SX-28 images, this is intended for DIY construction at home.
The main thing is that I have worked out how to get the VIAs as jumpers to work in routing.
Look at the next posting for the files. I had to revise these due to some obvious errors. I removed the bad files and now you have super squirrel.
I am hoping to follow up with this as a 4X board in a PDF.
Do we now have an SX-48 mascot? I suspect that somebody owns that image.
PLEASE CHECK THE PDF IMAGE IS ACTUALLY THE CORRECT SIZE before you go through the board making process. I do try to make sure, but printers and images be tricky. I suggest you print in the highest resolution (dots per inch) possible. What you see in PDF will be converted by what the printer is set to deliver.
