Is there a virtual propeller application?
Work is slow sometimes, and I can't bring my prop bread board in and have that hanging off of my desk.
Is there a virtual propeller application that I can load a program to, simulate some basic highs and lows to pins as if it was connected to the chip on a com port and then watch how the code interacts with that and outputs on pst?
Does viewport have this ability?
don't get catched doing private things at work
http://sourceforge.net/projects/gear-emu/
Propeller simulator in java
As usual Stefan, you are the man! I can't wait to try it out tomorrow.
S
http://obex.parallax.com/object/688
CON
_CLKMODE = xtal1 + pll16x
_XINFREQ = 5_000_000
OBJ
psg : "PropellerSignalGenerator"
PUB main | i
'Start "Propeller Signal Generator" and output signal on pin 10 (inverted signal on pin 11)
psg.start(10, 11, 32) ' Sync pin = 32 = No pin
'Point to an 8 samples big (2^3) U16 waveform in memory
psg.setUserWaveform(@userWaveform, 3)
repeat
'Generate a 200 Hz saw wave for 2 seconds
psg.setParameters(psg#SAW, 200, 0, 0)
waitcnt(cnt + 80_000_000 * 2)
'Generate a 100 Hz sinus wave for 2 seconds
psg.setParameters(psg#SINE, 100, 0, 0)
'Generate a 300 Hz user defined wave for 2 seconds
psg.setParameters(psg#USER, 300, 0, 0)
'Generate a 1 kHz sample and hold noise wave for 2 seconds
psg.setParameters(psg#NOISE, 1000, 0, 0)
'Generate a 20 kHz sample and hold noise wave for 2 seconds
psg.setParameters(psg#NOISE, 20000, 0, 0)
'Generate a 500 Hz square wave with 25% pulse width for 2 seconds
psg.setParameters(psg#SQUARE, 500, 0, psg#PW25)
'Generate a 50 Hz square wave with 50% pulse width for 2 seconds
psg.setParameters(psg#SQUARE, 50, 0, psg#PW50)
'Modulate the pulse width for a few seconds
repeat i from 0 to (1<<31) step (1<<14)
psg.setPulseWidth(i)
'Generate a 80 Hz triangle wave for 2 seconds
psg.setParameters(psg#TRIANGLE, 80, 0, 0)
'Sweep the frequency from 20 to 20000 hz
repeat i from 20 to 20000
psg.setFrequency(i)
waitcnt(cnt + 10_000)
dat
userWaveform word -$7FFF, $0000, $7FFF, $4444, $1111, $2222, $3333, $4444
