SimpleIDE linking a Spin/Pasm object into a C binary? — Parallax Forums
evanhevanh Posts: 17,060
edited 2015-02-06 13:50 in Propeller 1
I've just had my first poke at C on the Prop. Using SimpleIDE, I am particularly interested in marrying pasm code from the object exchange. My first look was to check out any existing examples and found one with libvgatext. It uses VGA.spin.
I can see in vgatext.c the Cog being launched with the VGA driver dat labelled reference. What I can't figure out is how the extern reference is filled. I'm not seeing anything in the sources.
I'm guessing there is some magic naming going on with OpenSpin compiling that is then matched up at link time?
  • DavidZemonDavidZemon Posts: 2,973
    edited 2015-02-06 12:23
    If I'm understanding you correctly, I think this may be relevant. Assembly files (the dat section from VGA.spin) and cogc files are treated similarly by PropGCC. The linking is very... magical. And difficult to get right.
    http://forums.parallax.com/showthread.php/158190-Can-t-get-cogc-files-to-compile.
    edited 2015-02-06 12:34
    evanh wrote: »
    The linker creates the names used by these embedded binary images. Yes, it is a bit like magic.
  • evanhevanh Posts: 17,060
    Thanks. I'll have a bit more of a read.
