Circuit Scribe is a rollerball pen that writes with conductive silver ink.
Bob Lawrence (VE1RLL)
Circuit Scribe is a rollerball pen that writes with conductive silver ink. It makes creating circuits as easy as doodling.
https://www.kickstarter.com/projects/electroninks/circuit-scribe-draw-circuits-instantly
Here you go:
CAD$29.84
CODE: Circuit Scribe
Quantity:
http://abra-electronics.com/chemicals/circuit-board-maintenance/circuit-scribe-conductive-ink-pen-draw-circuits-instantly-silver.html
How did they connect those surface mount LEDs shown in some pictures on the kick starter page?
Are they soldered, stuck down with the ink, glued or what?
Anyone tried this yet?
http://www.electroninks.com/
Scribbler 2 Robot:
I can see the Parallax scribbler robot making conductive circuits with a PEN in it's future
re:How did they connect those surface mount LEDs shown in some pictures on the kick starter page?
Bottom of module : you can see the conductors
I just can't justify to myself having to spend so much on a module so as to use a transistor or whatever.
Hence I wonder how you make connections to surface mount components.
I'd love to be able to draw tracks on glass to create LED arrays and other displays. With the resistive ink no resistors are required! They would be works of art done if done well.
Sadly it seems that ink formulation does not draw on slippery surfaces very well from the roller pen.
They are coming out with a resistor pen as well. Then you can draw the resistors direct
Anytime, what are you going to make?
Battery
http://www.electroninks.com/modules/
By the way, Jacob, the almost 8 year old has a Hubsan h107 that he flies much better than I do. Eva, the 6 year old flies it about as well as I do. What's with these kids these days?
