activitybot board programing help
i need help figuiring out how to combine the wiskers with the ping sensor to work to gether, i have the wireing done i just need help with the programing.
any suggestions would be most helpful
thanks i hope to solve this.
First of all, welcome to the forums!
On this page ( http://learn.parallax.com/activitybot/navigate-touch ), there is a tutorial for navigating using the whiskers, and on this page ( http://learn.parallax.com/activitybot/navigate-ultrasound ) there is a tutorial for navigating using the ping sensor.
It should be pretty simple to figure out how to combine the two. If I could have some additional information on what you would like to do once you combine them, that would make it easier to give more direct help.
Hope this helps,
ValeT
i want the wiskers and ping sensor to work to gether. in the same program at the same time.
