Detect capacitance change on a wire when it comes into contact with a second wire
Initially I thought resistance, but I think capacitance. I was looking at the Capacitive Touch Sensor from SparkFun, but this is for the human body.
I will have a 3' 18 gauge wire attached to a stainless steel plate that is less than 1 mm thick and 4" x 4". I need to detect a stainless steel rod that is 1/8 diameter 1' long striking the plate at the tip.
Any sample circuit and spin code would be appreciated.
You can only measure resistance when it's part of the measuring circuit and what you have is a piece of wire going off to a plate which may contact another plate which does not connect to anything else, that is not a circuit.
It may be possible to measure the capacitive loading affecting the rise time of a resistively coupled pulse on the line, the pulse is sent from one pin and another measures its rise time. But unfortunately I think that you may have a lot of noise issues. The best bet is to have the remote metal plate as part of a circuit.
