RN-42 Bluetooth device
iseries
This needs to be upgraded to Bluetooth version 4.0 compliant. This is where the new stuff lives.
We'll most likely have to replace this device to get that compliance since the updated firmware for the RN-42 removes functionality that was supported when we designed the board, but is no longer available.
I remember evaluating a Bluetooth transceiver from Adafruit that I was actually able to use to reprogram a Propeller chip over the Bluetooth connection directly from the PC Bluetooth COM Port. But as I recall it was not 4.0 / BLE either.
As a note, I have connected my Android phone to the RN-42 for many applications before. Including robot control, for example: http://www.savagecircuits.com/content.php?187-Bluetooth-BoE-Bot-Demo
If you do that, please consider an XBee module format version -- that would be great for the Activity Board. In fact, maybe you make a carrier for that which would allow XBees or the new BT module to be plugged into a standard breadboard (using the on-end connections like the present BT module). Just and idea.....
+1
Rick Galinson invited me to dinner the other evening -- it's always good food, talk about women, and talk about Propeller programming. I took my PAB with a battery an showed Rick the Android/BT connection. Funny how two grown men can get so excited seeing an LED come on after putting "HIGH 26" into a text box and pressing a Send button. For the things we do, though, the implications are big. Honestly, the BT side of that was the easiest; the bigger thing for me was creating a parser and token identifier code that allows me to handle natural language statements.
Is the Roving Networks XBee-socket-compatible version BT 4.0 / LE compliant?
-- http://www.mouser.com/ds/2/268/Datasheet-RN41XV-RN42XV-ds-v1%200r1-493475.pdf
