Li-ion Power Pack/Charger cables?
Just wondering why Parallax does not offer the cable(s) for sale? I think it would be more convenient to cut off the barrel plug end, then trying to find a connector for the other end.
The other question is, if you had two cables attached to a barrel plug, and the other ends attached to RAW power output and CELL power output, if this could work automatically when the RAW power IN was turned on and off? I think the circuitry right now prevents CELL power out when RAW power in is active.
Ray
Ray
Ray
Li-ion Battery Cable (#802-00020)
Ray
Ray
Ray
Jim
http://www.mouser.com/ProductDetail/TE-Connectivity-AMP/1-480698-0/?qs=OSEowtgdlxKxU5sgrqzhFw%3D%3D
Ray
Even if you found the correct connector, you would still have to order pins, then crimp or solder.
As mentioned before, just order Li-ion Battery Cable (#802-00020) from Parallax. Call Sales.
Ray
You know the old saying...
"If you don't take care of your customers, someone else will."
dgately
However, I noticed that the Parallax made charger (#28986 included in the #28989 Li-ion Power Pack Full Kit) uses the same exact cable and since Parallax actually makes that charger, they should be able to provide the part number for the female Molex connector they use on the board. It would then be easy to locate a matching male connector for the cable.
