integer to ASCII object?
Hi All,
I googled and searched the obex but didn't find an integer to ascii converter. I did see reference to there being something of the sort in PASM in fullduplexserial and similar, but not being a ASM guy I couldn't figure it out.
Before I start trying to write one, does anyone have one handy?
Thanks!
Jonathan
Thanks!
Jonathan
The "Numbers" object in the Propeller Library has methods to format numbers as characters in a string.
I like to use the object "StrFmt.spin" when converting variable to characters. There's a copy of the object in my GitHub "EddieFirmware" repository.
PRI itoa10(number, str) | str0, divisor, temp {{ This private routine is used to convert a signed integer contained in "number" to a decimal character string. }} str0 := str if (number < 0) byte[str++] := "-" if (number == $80000000) byte[str++] := "2" number += 2_000_000_000 number := -number elseif (number == 0) byte[str++] := "0" byte[str] := 0 return 1 divisor := 1_000_000_000 repeat while (divisor > number) divisor /= 10 repeat while (divisor > 0) temp := number / divisor byte[str++] := temp + "0" number -= temp * divisor divisor /= 10 byte[str++] := 0 return str - str0 - 1Jonathan
' add this in var section byte n_string[12] ' string buffer for inttostr and hextostr pub inttostr(i) |q,pos,k,j '******************************************************************************** ' ' Convert integer to dec string ' Return a pointer ' '******************************************************************************** j:=i pos:=10 k:=0 if (j==0) return string ("0") if (j<0) j:=0-j k:=45 n_string[11]:=0 repeat while (pos>-1) q:=j//10 q:=48+q n_string[pos]:=q j:=j/10 pos-=1 repeat while n_string[0]==48 bytemove(@n_string,@n_string+1,12) if k==45 bytemove(@n_string+1,@n_string,12) n_string[0]:=k result:=@n_string pub hextostr(i) |q,pos,k,j '******************************************************************************** ' ' Convert integer to hex string ' Return a pointer ' '******************************************************************************** j:=i pos:=10 k:=0 if (j==0) return string ("0") if (j<0) j:=0-j k:=45 n_string[11]:=0 repeat while (pos>-1) q:=j//16 if (q>9) q:=q+7 q:=48+q n_string[pos]:=q j:=j/16 pos-=1 repeat while n_string[0]==48 bytemove(@n_string,@n_string+1,12) if k==45 bytemove(@n_string+1,@n_string,12) n_string[0]:=k result:=@n_stringAlso, FYI, "j"=0-j" can be written as "-j". When the variable is by itself the minus sign negates the variable's value. Dave's "number := -number" could also be reduced to "-number".
PUB Dec( value ) | denom {{ * Sends a decimal number over the serial link. > value : the number to send. e.g. Dec( 10 ) ' sends "10" }} ' if negative, note that if value < 0 ||value tx( "-" ) ' start with the largest possible power of 10 to fit in 32 signed bits denom := 1_000_000_000 repeat 9 ' I have a non-0 digit, or we already had one if result |= (value => denom) tx( value / denom + "0" ) value //= denom denom /= 10 ' always show the last character (and denom == 1) tx( value + "0" )JonathanI have spent the last while reading and boy, my ignorance is amazing. For starters, I wasn't really asking the right question. I think I'll start a more appropriately titled thread.
@Jonathan - that is a useful snip. I'll need that. Thanks.
It does not take in to account that Spin variables are signed and can be negative, maybe I update that.
{ Sends a 10 character DEC of a HUB Address value, at a fixed interval } PUB start(address) cognew (@entry,address) DAT org 0 entry mov DIRA,_bit30 mov cnt,#7 '7 cycle overhead add cnt,cnt 'add current cnt loop1 waitcnt cnt,#200 'wait and then add 200 for below overhead rdlong temp,PAR movs decimal,#table mov charcnt,#11 '10 dec chars in a long + space loop2 mov uartTx,#48 'start at ASCII for "0" decimal cmpsub temp,0-0 wc 'try 1 Billion first if_c add uartTx,#1 if_c jmp #decimal cmp charcnt,#1 wz 'last charter one? if_z mov uartTX,#32 'replace with space or uartTx,#$100 'set stopbit shl uartTx,#1 'merge in startbit mov bitcnt,#10 '10bit uart loop3 waitcnt cnt,_baud shr UartTx,#1 wc muxc OUTA,_bit30 djnz bitcnt,#loop3 add decimal,#1 'try 100mill next djnz charcnt,#loop2 add cnt,_second 'restart main loop with 1sec delay jmp #loop1 _second long 80_000_000 '/2 or /4 if you want shorter delay (insert -76540 if you want absolute sec-to-sec timing) _baud long 80_000_000/115200 _bit30 long |<30 table long 1_000_000_000, 100_000_000, 10_000_000, 1_000_000, 100_000, 10_000, 1_000, 100, 10, 1,1 temp res 1 charcnt res 1 bitcnt res 1 uartTx res 1Very cool.
I've wondered about reading messages directly in PASM. I'm pretty sure manipulating characters in Spin is a bottleneck in many of my programs.
Thanks for posting your code Tony.
