Help with building propgcc on Linux Mint
Mark Mara
I am getting the following errors when trying to build propgcc on a Linux Mint (17.1) machine.
I am new to Linux so I have probably have something configured incorrectly. I have attached the complete output from the build attempt. Any hints about where to look for the problem would be greatly appreciated.
--markM
make[3]: *** [info-recursive] Error 1 make[3]: Leaving directory `/home/mam1/prop-src/build/binutils/bfd' make[2]: *** [all-bfd] Error 2 make[2]: Leaving directory `/home/mam1/prop-src/build/binutils' make[1]: *** [all] Error 2 make[1]: Leaving directory `/home/mam1/prop-src/build/binutils' make: *** [/home/mam1/prop-src/propgcc/../build/binutils/binutils-built] Error 2 mam1@mam1-Macmini ~/prop-src/propgcc $
--markM
The build instructions on the wiki have a note about this error - you'll need to downgrade you version of texinfo
https://code.google.com/p/propgcc/wiki/PropGccBuild
