Two sided PCB question
Hi All,
If one is laying tracks on the top of a two sided board, is it recommended to put a ground plane? On the bottom the entire board is ground plane and the tracks are little islands. Should it be the same on top?
Thanks!
Jonathan
Thanks!
Jonathan
Here's a pretty good basic guide to pcb layout. The guy who wrote it is very experienced and has been in the electronics industry for many years. You may have heard of him.
http://www.alternatezone.com/electronics/files/PCBDesignTutorialRevA.pdf
Having bottom as gnd is good as when you need to connect something to gnd you just apply a via.
Top pour could also be gnd or it could be Vdd
Or it could be a mix of them if you have RF or need to dissipate heat from a IC pad etc
Thanks for the replies. I am doing pretty simple boards and wondered if there was a standard. I like the idea of saving copper, although I'm not etching these boards. I have recently started the CAD route after years of DIY PCB's. I just never got things fine enough for todays small parts. I also like the idea of some copper for a heatsink, wish I had done that for the vreg on my last (and first CAD) board.
So much knowledge on these forums.
Jonathan
