ACTivity Bot Calibration Program Loaded into EEPROM -Delete/Erease/Load new progr
A . Question
Functionality great ! - but how do I delete the calibration program in the EEPROM ?.
I'm assuming it must be deleted if I want to load in "joystick /board - controlled Activity Bot programs -see attached
B.) Is the attached programs in the Learn Folders or library or do I just cut and paste into SimpleIDE editor
see the attached
see the attached
I believe the calibration data is saved in the upper 32K of the EEPROM. Every time you write a standard SPIN program, it writes to the lower 32K of the EEPROM, leaving the calibration intact.
