All built and ready for testing
Ok I built my activity bot, and double checked all the connections. Ready to start testing. Any suggestions? I still don't know if my Mac's 10.6.8 OS WILL SEE IT, but I'll soon find out. If it doesn't communicate, I can't hurt a thing right? I remember reading somewhere NOT TO PLUG IT INTO USB WITHOUT INSTALLING THE SOFTWARE. I attached an image. you can leave the batteries in while being connected to usb right?
What do you mean by "it seems to crash"? Does it simply do nothing (besides the terminal opening) or does it print garbage all over the screen? If there's garbage on the screen, then you're baud rate is wrong. Or does the compiler or loader complain? (but then the debug window probably wouldn't come up)
I'm pretty sure OSX comes with FTDI USB drivers, although you can also download OSX drivers from FTDI's website. I'm not sure what the difference is between the two drivers, or if there even is any difference. If you can program or even identify your chip, then your drivers are fine.
The warning about not plugging in the device until you've installed drivers is because Windows does silly things when it can't find drivers instead of just admitting that it doesn't know what to do and giving up. You should be fine on OSX.
Hi, I used Simple Version 1.01 and drivers used was 2.218 64 bit. My iMac is a core duo2 running in 64 bit. Mac OS 10.6.8.
