Need help with Back EMF Protection for dual-direction DC motors.
Hello everyone,
At the moment, I am working on a simple robotics project, powered by my Basic Stamp Homework Board.
The layout is basically this:
http://letsmakerobots.com/start , but I am using my Stamp as the microcontroller. I have pretty much everything set up and ready to go, but am stuck on one small problem--back EMF protection.
It is a new concept to me, but I was able to easily understand back EMF protection for a single direction motor by reading this:
http://www.instructables.com/id/Using-the-Sparkfun-Motor-Driver-1A-Dual-TB6612FNG-/step6/Sidetrack-Back-EMF-Protection/
and this:
http://www.progeny.co.uk/Back-EMF-Suppression.aspx.
However, back EMF protection for dual direction motors (http://www.instructables.com/id/Using-the-Sparkfun-Motor-Driver-1A-Dual-TB6612FNG-/step7/Add-Back-EMF-Protection/has alluded me so far. I looked at this:
http://www.instructables.com/file/FYEO8QZH21CGJYJ
and wasn't able to understand how this could allow the current coming from the motor to loop back to the motor. This:
http://www.learn-c.com/l298sideacircuit.gif
basically shows the same thing. To be honest, even this simpler diagram doesn't show me how this rectifier diode setup will provide back EMF protection.
I know, I know. I could just mimic these pictures/diagrams and everything will turn out fine. However, I need to understand this because:
1. I am using a bit of a different setup, using two different power sources (one for basic stamp and motor driver, one for motors). This knowledge will help me to get the right setup.
2. I will never be able to apply this to other things if I don't understand the underlying facts of how it works.
3. Curiosity.
Thanks in advance for your help,
Beginner4
and this:
3. Curiosity.
Beginner4
the current flow builds up a magnetic field around the wire -
Next switch Out1 to 0V and the magnetic field collapses thereby inducing a current flow in the opposite direction (negative) in the wire.
This current goes through the diode to ground, since it tries to go to -5V. Luckily it gets clamped at the forward voltage drop of the diode.
Now reverse the polarity on the motor. The same scenario plays out on Out2.
Does this answer your question?
That does make sense to me now, thank you.
However , I'm left with two more questions after that.
First, in the schematic, why won't V+ flow directly to ground, creating a short circuit? I think there is something fundamental I may be missing here.
Secondly, what is the purpose of the Ground to the left of the motor?
Beginner4
The ground is there to give a path for collapsing magnetic field current to get back to the PS.
Good luck with your projects
It seems that everyone says EMF 'kicks back', causing current to flow in the opposite direction. But then, I look at a picture like this:
http://www.progeny.co.uk/wp-content/uploads/2014/01/image003.png
Which seem to show the current travelling in the same clockwise direction as it did before 'back EMF' kicked in.
Addiotionally, looking at picture like this:
http://www.instructables.com/file/FYOQEOFH2G5ZV1U
Seems to testify to the fact that EMF current continues to travel in the same direction as when it was powered by the battery. This is because, to my understanding, the diode provides protection by allowing the current to make a circuit back into the motor when 'back EMF' occurs.
I appreciate the help, Domanik, but something is just not clicking for me.
Thank you,
Beginner4
Ok. After continued reading and thinking about it, I now understand this. Thank you VERY MUCH.
Basically, in this setup:
The current is directed back into the motor. Whereas, with dual direction motors, the current is directed to ground instead.
Just another question that I still don't understand. Up at the VERY TOP of the circuit, it appears to me that Motor V+ is attached directly to ground... why wouldn't it just flow straight to ground? Is it because there is a stronger attraction to -5V?
Thanks so much,
Beginner4
Let's say when the motor goes CW you have +5V on Out1 and 0V on Out2. When it goes CCW you have 0V on Out1 and +5V on Out2. (I'm assuming your motor is 5V for simplicity).
OK, thanks.
That explains that, but disproves what I thought I understood earlier. Sorry, I'm just having a really hard time understanding what's going on.
So, to break it down, when the motor is being driven CW, Out 1 is connected to +5V and Out 2 is connected to ground (and vice versa for CCW). This causes current to flow through the motor.
After power from Out 1 is cut, the dangerous effects of back EMF kick in. The diodes are positioned in a way so that they protect the fragile components of the circuit against this back EMF.
Now my question is, how do the diodes do this? (I know we have gone over this, but it just didn't click for me). If someone could give me a picture of the shematic with the pathway of current through the diodes during back EMF, I think that would help me understand this.
To my knowledge, those diagrams show how current flow while the motor is being powered. What I need to know is the path of current of back EMF through the diodes.
Basically, if someone could just simply draw on the schematic, drawing out the path followed by current flow during back EMF. Just show me how the current is directed through the circuit so as to save the more fragile components.
Thanks everyone so much for helping me out. I know I am not grasping the concept 100%, so thanks for all your help,
Beginner4
When the motor free wheels it acts as a little generator (it has its own permanent magnets) and the Back EMF adds to the drive voltage showing up on the outputs. If this voltage goes over 0.6V it is clamped to GND or VPwr. I tried to simulate this in the attached schematic but my V1 voltage source does not make a great model of an EMF pulse. An EMF should be +V, 0 and -V instead of only 2 levels.
Schematic: Schm1.pdf
Simulation: Schm2.pdf
Good Luck.
Take a look at this site:
http://www.electronics-tutorials.ws/inductor/inductor.html
About half way down the page you'll find a short discussion about "Current and Voltage in an Inductor". There's a diagram that helps explain "back EMF".
Yes, there is some math involved - but it's not too bad.
motor over-run (when the motor turns faster than its normal top speed), which will drive a larger voltage into the supply
that its designed for. This is why you have to be careful about pushing wheeled robots - push them too fast and you can
damage things.
