Modbus rtu on propeller
Hi.i want to connect 1 pc (master) and 10 propeller (slaves) with rs 485.i want to use modbus rtu for the protocol.
Are there anybody who try this before.any code sample?
Others have done the same.
My code is attached.
It has LOTS of fuzzy edges right now and is NOT complete, but it might help. Constructive critism welcomed
Modbus_PAC.spin
I want to test the code pacman.then I want to say my ideas
Need some help with Modbus RTU implementation on the Propeller Activity Board using the Modbus_PAC code. The setup is as follows:
PC <--> (RS232-RS485 Converter) <--> Propeller with RXpin = 9, TXpin = 8.
To test implementation, I am using the QModBus simulator to issue commands.
The code receives commands from the PC (QModBus) properly. For example read holding register (x03) is received and the ReadRegisters and SendOut functions are executed. I tried PST to see the returned value from SendOut. It looks the correct value. But QModBus shows error "Slave threw exception > unknown error".
Any thoughts what could be the reason.
Thanks....
I'm not really sure how your system is set up but Modbus RTU doesn't use ASCII characters. If the data is showing up in PST, then I'd think it's not formated as Modbus RTU.
Thanks Duane....This is the bit of code in the function SendOut that does transmit using FullDuplexSerial object.
PRI SendOut (buf)| j
' Transmits the data back to the host system.
' params: buf - the data stream we want to transmit
' return: none
'NOTE the first element of the array contains the length of the array thus we need to send out buf[0] bytes of data
PST.newline
PST.str(string("Send Buf"))
PrintBuffer(buf) ' just for debugging - delete later if required
'ser.RxTime(500)
'ser.RxFlush
'repeat j from 1 to byte[buf][0] -1
ser.Tx(byte[buf][j])
PrintBuffer prints to PST, it is as follows:
PRI PrintBuffer(print) | k
' Just dumped the buffer to the debug terminal
' this method can be deleted once all testing has been done. Any call to Printbuffer can then ALSO be deleted.
PST.newline
PST.str(string ("PrintBuffer "))
repeat k from 0 to (byte[print][0] -1)
PST.newline
PST.hex(k,2)
PST.str(string (" : "))
PST.hex(byte[print][k],2)
The code is fetching correct data from the holding registers and the CRC calculation is correct, but the transmit back to master is failing for some reason. I am not sure if its the formatting of the transmit frame or something else.
The Modbus RTU object from OBEX is attached. Any help is appreciated.
I worked on a project which used Modbus RTU and I was successful in getting the Propeller to communicate with the Modbus master (I wrote my own Modbus code, I didn't use the object in the OBEX) but I'm far from an expert on the subject.
One thing I do know is there are lots of variations in the way data is formated. IIRC the data is generally sent most significant bit first but the order in which the bytes are sent isn't always consistent among the various Modbus devices.
If you post your code with code tags hopefully someone more familiar with Modbus will help.
It does look like you're treating the data correctly to display to the PST.
Many Modbus devices expect the data to come in with even parity (which none of the commonly used serial objects use). Many of the serial objects send an extra stop bit (at the beginning of the byte) which can also cause a problem with some devices.
I'll try to find the post about how to add even parity and I'll also try to find Tracy Allen's comments about the extra stop bit.
http://forums.parallax.com/showthread.php/155390-Adding-Even-Parity-to-One-Port-in-Tracy-Allen-s-4-Port-Serial-Object
IMO, there's a lot of good information in the thread.
I seem to recall that in certain cases Modbus *requires* 1.5 stop bits. Don't remember just now what that was for precisely..... some kind of over-riding function I think.
Cheers,
Peter (pjv)
-- http://www.rtaautomation.com/technologies/modbus-rtu/
Cheers,
Peter (pjv)
Slow the the comms (serial sometimes benefits from running slower)
Try a different convertor (sometimes different brands do 'odd' things' - slowing down comms here can often help)
Check your 'endian' setting in Qmodbus (though I would also expect the command from the PC to be in error if this was the issue)
Check the bounds of the command - Modbus has different method of defining where a register array starts - Try reading/wring one register in the middle of the array (that way the whole +1 -1 offset is removed)
Check your not using Enron Modbus (as it does stuff slightly differently to 'normal' modbus - though I would also expect the command from the PC to be in error if this was the issue)
Capture the send command (from the PC) and the receive command from the Prop and post them here, then I can see if something more sinister is going on (in my prop code perhaps).
