BS2 download trouble
Hi everyone,
I have the Professional development board. I have used it for a long while with the serial port on my PC with no trouble. I recently had to upgrade, and the PC had no serial port, so I got one of the Parallax USB serial ports. The problem is, whenever I try to download [run / run or F9] it will often give me the error communication failure, check power supply message. Sometimes instantly, sometimes part way through the download. It can take anywhere from one to several tries before I get a successful download. I've tried 3 different USB hubs, and also direct to a USB on the PC. What is going on?
Thank you,
Dave
Thank you,
Dave
I'm assuming you have the USB-to-Serial Adapter?
http://www.parallax.com/product/28030
I know there has been some problems programming a Propeller through a USB 3.0 interface. Does your new PC have blue colored USB connectors? If it does, check to see if it has USB 2.0 connectors and try them.
Is your USB cable one of the thin retractable kind?
It is really being stubborn today. I just tried 10 or 20 times, and never got further than 1/8 of the download done before the error came.
The stamp is a BS2P The big one with 2 banks of 16 I/O lines
http://www.parallax.com/downloads/parallax-usb-driver-installer
I have also now uninstalled and re installed the driver from FDTI. No change.
OS is Win 7 64 bit
That's a clue - the listing does not show the COM# It shows up as : USB Serial Converter.
I did just a bit ago re touch the solder on the USB connector pins. It has downloaded 3 times successfully since I did that, one time it did the fail check power thing. I'll see as I continue working on the program... Yesterday, it would not work. I ended up going to another PC with a real serial port, and downloading with it, but that's a big pain to have to do.
I did just a bit ago re touch the solder on the USB connector pins. It has downloaded 3 times successfully since I did that, one time it did the fail check power thing. I'll see as I continue working on the program... Yesterday, it would not work. I ended up going to another PC with a real serial port, and downloading with it, but that's a big pain to have to do.[/QUOTE]
Today, it is back to not working. I just tried it a buinch of times.
So back to the driver problem....
It's been working about 1 out of 6 attempts today..
I'll have to bring my copy in tomorrow to try it.
Thank you,
Dave
Jeff,
Are you trying to program the BS2 via XBEE? If so, this is not supposed to work. Even if you had DTR your timing would not be tight enough to program the chip.
There is a product that has been developed for just this purpose:
http://www.parallax.com/product/28183
Jeff
I just tried it now. [A bunch of other stuff kept interrupting me]
It initially downloaded a few times. Then began the random hangs at various completion levels, just like the other adapter.
Dave
How does this alternate adapter show up in the device manager?
You're using a different programming interface entirely. In your case I would update the drivers associated with your device to see if that fixes the issue. If you continue to have issue you may want to start your own thread since these issues aren't related to what is in this thread.
The project that started this thread was interrupted several times. Then finished.
The problem still exists.
I am now working on a project of my own. Initially, I was having only rare download failures. As the program has grown, I now only rarely get a successful download.
I just updated the driver, and still fail.
Driver - FTDI
7/12/13
2.8.30.0
This system is win XP. The USB port shows as USB Serial Port (COM3) in the device manager.
I have a number of BS2 stamp boards, and which one I am working with seems to make no difference.
It's worked for 2 downloads so far, I'll update after some more....
It has been working well since.
Thank you.
