Generating Electricity from Heat to run a Prop
JohnR2010
I'm looking for a power source that would generate 10 to 200mA at 2.8v from heat to temporarily run a propeller. I'm working on a fireplace flew temperature monitor and I would like to pull the power straight from the heat in the flue. I have done some searches on the Internet and man there is a lot of Smile out there. I don't want a do it yourself science project, I'm looking for a reliable solution. I thought I would post a question here and see if the forum has any recommendations on a place to start.
Thanks!
Thanks!
http://www.biolitestove.com/products/campstove/
Not cheap though to extract the components.
Could it be that thet TEG (Thermoelectric Generator in that BioLite device is simply a Peltier effect junction that is being used in reverse?
It is called the Seebeck Effect.
http://en.wikipedia.org/wiki/Thermoelectric_cooling
http://en.wikipedia.org/wiki/Thermoelectric_generator
If so, just DIY a few to the side of the stove.
Here is a photo of the Biolite campstove teg arrangement. You can see the copper stake that goes into the hottest part of the fire and projects through an opening in the stove body. The insulating pad sits against the outside of the stove. Heat is carried up in intimate contact to one side of a TEG while the other has a form-fit fan cooled heat sink visible through the slots. The outflow of the fan goes into the firebox to help oxygenate the fire. Electronics step the voltage up to 5V for the USB charge connection. There was a lot of engineering that went into that.
Radio Transmission I guess.
Are you trying to sample the temperature and send it with Radio to receiver?
If this is the later, a CC430F5123 with two AA batteries should last 5years, so maybe go that route?
It have built-in CC1101, but I think you want Zigbee so a maybe: http://www.ti.com/product/cc2530/description
Or do this:
https://devworksinprogress.wordpress.com/2011/06/18/project-zigbee-temperature-sensor/
With an energy harvest circuit and a Ultra Cap I wonder if I would be able to build up a charge to power up the propeller and have it check in. I have zero experience with an energy harvester circuit. I see Sparkfun has one that can output 3.3v https://www.sparkfun.com/products/9946, does anyone have input on this? I also see Linear Technology says they have ICs that can harvest energy from a Thermocouple. I was planning on using a Thermocouple to measure the temperature anyway. Looks like I have my reading materiel for the afternoon.
I hate to make the jump away from the Propeller but it is on my list to do for the coming year. When I make the jump I was planning on doing it with my first Bluetooth project and I see TI has a Bluetooth System-on-Chip CC2540. I will also take a look at the cc2530. Even talking about this makes me feel like I'm cheating on my wife?? I do love her so!!
Thanks Tony!!
Thermistor hooked up to the Enable on LDO, if temp is low the whole system is shut off.
http://mouser.com/Passive-Components/Thermistors-PTC/_/N-796na?P=1yzmno7Z1yzeki4Z1yzekj6&Ns=Pricing%7c0
Maybe have to apply additional 100K resistance as to get Thermistor standby down to 1uA
When fireplace is in use, Send data for 1second 60 times an hour at 50mA, sleep the other 59minutes an hour at 0.1mA
Equal an average of 1.87mAh a day, 224mAh for the season.
1500mAh batter should last 5years accounting for a 2% self-discharge , use alkaline or non-rechargeable (primary) Lithium batteries
He has follow up videos on a grander scale. I really like this guy !!
https://www.youtube.com/watch?v=zzEK5eODr6I
Here is a photo of an arrangement we made here (in cooperation with Johnathan Cedar, founder of Biolite) to capture heat energy to run a data logger with wireless from the heat of a flue. An aluminum block is cut with a 4" radius to fit tightly the contour of the flue, and the TEG is sandwiched between that and a heat sink in a chimney arrangement to help with convection cooling. The data logger with XBee is fastened on the outside of the chimney.
With the fire running full tilt in this particular stove, the surface of the flue went up to ~100°C, but the hot side of the TEG only up to 70 something, and the temperature difference across the TEG with the passive ventilation hovered around 20°C. Both the voltage and the current into a matched load are proportional to the temperature difference across the TEG, so the power is roughly proportional to the square of temperature. The power output approached 50mW peak, but during most of the stove operation was closer to 10 to 25 mW. Fading to less than 1mW as the fire went out.
We tried a combination of chips to harvest that energy, LTC3105 for the peak production, LTC3108 for the long tails, down 50mV from the TEG, and the LTC4071 for LiPo charge management. In the end, the TEG did not produce enough to run the logging and wireless protocol we wanted. The project ended up relying on a larger battery pack.
Of course, you might consider something more exotic.. a Sterling engine. They actually seem to operate well on a small scale. Some have actually been commercialized in the range of a few horsepower. The problems of engineering become more and more substantial as one tries for greater power outputs.
http://www.ebay.com/bhp/stirling-engine
en.wikipedia.org/wiki/Stirling_engine
https://www.youtube.com/watch?v=s2I9OoZs4Wc
With a blow lamp on one end they generally managed to turn over. The better made ones, like mine:), achieved quite a lick. But I still can't imagine getting enough power out of them unless they are somewhat bigger and better engineered.
But as we are talking flew gasses here that implies a lot of heat and high temperatures are available. Which Stirling engines love of course. So perhaps that is a solution. It's not going to be simple or cheap though.
Tracy, It was very interesting to read about your experiment. This subject comes up from time to time here on the forum but this is the first time I've seen some hard numbers of the power output of one of these devices. So much for the idea of putting a TEG generator behind solar panels as I've seen suggested.
Did you try actively cooling the cold side of the TEG? With the small power output I think it's unlikely active cooling would generate more power than it required but as you pointed out in post #4 the Biolite gadget uses active cooling. Of course the Biolite has its hot side pulling heat right from the heart of the flame.
Thank you for your posts. I found them very interesting.
Modules for sure can be combined - actually a single module is a array of peltier elements wired series-paralel.
This is the stove in operation in our parking lot. The collaborators in the photo are Ilse Ruiz Mercado, now at UNAM, and Jonathan Cedar founder of Biolite. This was an early prototype for Biolite, and the casing of the TEG unit on the side of the Stovetec rocket stove was 3D printed. Jonathan was helping us with a UC Berkeley project on measuring performance and adoption of improved stoves. Here we were testing the data logger and the range of the XBee wireless.
I took the stove on a trip up to Yosemite Nat. Park and this is a graph of a typical cooking session. Once the fire gets going, it produces enough power to run the blower on its own. This was also hooked up to the data logger (Prop with 16-bit ADC for thermocouples) and XBee wireless to view real time data. The temperature difference from hot to cold side of the TEG in this case hovered around 130°C during the cooking (orange line), and generated up around 3.5W (blue line).
Last year Biolite made a TEG firepit that generates 1000W to power a Christmas tree in Brooklyn.
Here is my circuit board and schematic. This also includes an LTC4070 LiPo charge regulator.
And performance data...
This is fine for a µpower data logger even with an occasional high power burst. A 10mA to 200mA requirement would definitely have to come in bursts to meet the average that could be supplied by this chip. The LTC3105 is another harvester chip, capable of higher output and MPPC starting at about 250mV input.
