Prop and Zone Valves
Hi All,
I recently purchased a 40 tube solar thermal heater for my hot tub, replacing my old flat plate heaters. I'm going to be making a real fancy solar powered tub this time and I want to use zone valves, at least I think I do.
I'll need at least two 3-way valves and a couple of 1-ways. My questions are:
Any brand recommendations?
I see different configuration. Are some easier to drive than others?
Seems like most are 24VAC control, so should be able to get some SS relays.
Any information on zone valves at all appreciated.
Jonathan
Jonathan
I have worked on Honeywell and Siemens zone valve actuators with proportional controllers. They are powered by 24VAC and are controlled by a 0 to 10V analog signal. Is this what you have in mind, or do you want only open/closed or multi-position type valves?
So I need simple open/close type valves. Two straight through and two "wye" types, they may call them diverters? This will allow me to switch between heating the tub and the tank. I also have a wood burning heater (a Chofu) in the system and may even bring in an antique 1930's sidearm heater that I restored.
Jonathan
J
Home Depot here in Canada carries 1/2 inch zone valves from Watts Water Technologies for $79.30. You might also be able to adapt regular plumbing valves or washing machine solenoid valves to do what you want. Two and three way valves are also available but they are pretty pricy.
What sort of controller do you want for the valves, on/off or modulated?
I'm not married to zone valves, but it seems as if they are a good fit although expensive. Being able to get parts to repair instead of replace is one of the aspects of the zone valves that I like, as well as the fact that they are rated for the.temps I am working with. Are some.easier to ctrol? Is there a brand you recommend?
Many thanks for the help!
Jonathan
I am in the planning and building a solar heating / pool system for our house in Spain as well.
Regarding a zoned storage and it's loading preserving the thermal layers, there is an alternative to the usual zone valves.
It comes from passive solar systems.
To preserve the thermal layers it is important to feed at the level with - more or less - the same temperature as the feed
to not create thermal currents that mix up the layers.
This can be done with an external 'feed-pipe' this is a relatively thick (5 to 10 times the area of the pipe) vertical pipe,
that has a many connections to the storage tank as you have available.
The hot pipe is connected to the middle of the 'feed-pipe' so the water can 'decide' by gravity at which level it 'wants' to flow into the tank.
The outlet back to the collectors is taken from the bottom of the storage tank.
no valves, no sensors, no controller, no extra energy ... just let nature do it's work
AND - you want to run the pump at low volume flow - otherwise you will mix as well.
--markM
@MJB- I am past the point where I could go for thermal siphon, although I see the beauty and my wood burning heater uses a thermosiphon. However, the tub is already located 10 feet below the solar thermal. I have also located the storage tank. So pump it is.
@Mark- Thanks! The relays you mention look great and great price. What is a C3 controller? I want to use a Propeller.
Thanks for all the replies!
Jonathan
http://www.parallax.com/product/32209
--markM
You use a pump to feed the hot water into the storage tank.
But you use gravity to let the water find it's way into the tank at the perfectly right level.
This saves the zone valves, sensors, controller, power ...
I think this one would be suitable for part of your system:
http://www.globalindustrial.ca/p/hvac/pumps-circulators/hydronic-valves-accessories/honeywell-24v-low-voltage-motorized-zone-valves-35-capacity?infoParam.campaignId=T9F&gclid=CMDzltLq3MICFasRMwodPVUA2Q
Another thing you need to do is to draw a diagram of the entire system with the location and type of zone valve. Building automation systems generally use normally open valves in cold climates so that heat stays on if the control system should fail. You will need to decide where you want the valve open in case of failure, and where you may want it closed.
@mark- Thanks! That valve is one of the ones I have been looking at. I have made my diagram and know that I need two wye valves and two straight through's. I do have the NO/NC situation figured out. This system will be partially a drain-back, so the NO side of the wyes will be oriented for this.
As for controllers, I will be using a Prop/Xbee combo, I am working on modifying a PCB layout and hope to have the boards in a few weeks.
Many thanks for the help folks!!
Jonathan
Use this valve in closed loop hydronic systems that do not contain dissolved oxygen in system water, such as fresh water from frequent source of makeup water. Valve designed for cycling (not constantly powered on) applications.
Why is this? And a hot tub does not seem to fit that description.
Thanks!
Jonathan
No, a hot tub does not fit that description. Oxygen in the water promotes corrosion. Most heating systems are closed loop and only add small amounts of water to make up for losses, and may have anti-corrosion additives. Can you post a piping diagram of the system?
The thing now is finding valves that will be OK. My guess is that those valves would probably be fine. In a hot tub the combination of hot water and bromine is always hard on copper but brass seems to do pretty well. In my experience with hillbilly hot tubs, copper lasts for a number of years but does run into problems. Brass seems to do fine. I have very low bromine levels and hope to switch to ozone. In any case, stainless valves are beyond my means. Plastic is attractive in some ways, but the 50 gallon storage tank is going to run pretty hot.
Jonathan
OOps, just saw I've been mixing up Mark and Kwinn. Sorry guys
Or you WANT sensors ;-) - to document everything on SD and display it on the web-site set up with Peter's IoT5500 ;-) ...
I will place at least 6 or 8 sensors on the storage tank to get a 'picture' of the temperature distribution.
To check that the tank is really layered and not stirred up accidentally.
8 will make a nice 8x8 LED-Matrix display .
as for link - I picked it up on some german solar DIY sites and all using it are happy with it.
And if you just think it thru it is actually very simple.
The external vertical pipe with wide diameter gives a slow vertical current that will feed automatically at the correct level
into the tank. And the vertical currents are outside of the tank so the tank is not mixed up.
The temperature layers are untouched and stable.
It requires a little more 'passive' HW but you save the 'transistors'.
For my tank I will get a custom welded feed-pipe (might not be much cheaper than the zone-valves unless you have somebody doing it cheap or you can do the welding yourself)
The fat pipe I picked up at the scrap yard. - and of course it needs to be insulated as well.
Since I will be using under floor heating I will have very low return flow temperatures which makes best use of the stored energy
when the tank is NOT mixed up. And the top is still nice hot.
I also think that brass zone valves would be ok, particularly in the heating/storage tank portion of the system. The hot tub water will be much cooler (95-106F? I found 105F to be the max I could handle.) so plastic zone valves would work there if they are available. This is why I wanted to see a diagram of the system. It might even be possible to adapt standard plastic valves to the same actuator as the brass valves.
Not sure ozone is an improvement over bromine though, OO2 is even more reactive than O2. If the hot tub water is isolated from the heating system by only dumping water in to the hot tub or using a heat exchange coil you could use plastic valves.
No problem, that's what I thought.
http://www.clare.com/home/pdfs.nsf/0/8471676520A90EC185256F5600507F99/$file/CPC1976.pdf
What do ya think?
Jonathan
Thanks!
JOnathan
Oops. Dropped a zero. .07, not .7 amps. Duh. Thanks for the help, just added some to my cart.
JOnathan
So, another question: I am designing a board for the relays and was wondering if I should put a weak pulldown, say 100k, to keep the relays off when powering up?
Thanks so much for all of your help. Really.
Jonathan
Not really necessary. The leds require quite a bit of current to turn the output on. Propeller pins as inputs (floating) provide virtually zero current, and the uln2803a already has pulldown resistors on chip.
PS You're posting questions in this and the propeller forum on the same topic and it's causing a bit of confusion
