VGA connector issue
I had a circuit board printed to connect a 15 pin D-sub connector to the Propeller using pins P8-P15 rather than P16-P23 as shown in the examples. The problem is that I seem to have reversed the order of the pins. I believe the basepin is normally on the 'V' pin but I will have the basepin on R1. Is there an easy way to modify the VGA driver object to reverse the pin order (i.e. set P16 as the basepin looking back to P8 as opposed to the basepin on P8 looking forward to P15)? Or am I going to have to start cutting circuit traces and modifying the PCB?
Is this just a adapter for VGA or is more on the board? If just adapter - thinking sideways again - can you just turn around that one 180 deg.and connect correctly?
Else you might need to cut traces and solder wires.
Enjoy!
Actually modifying my PCB will not be as difficult as I first thought. Some of the traces can be removed and the resistors can be connected to the 15 pin connector with some small hookup wire. I suspected there probably would not be an easy software fix, but you will never know if you don't ask.
Andy
