C language: what does pause(0) do?
John Kauffman
For following I expected "hello" repeated on screen. I get one "hello" only.
What does arg of zero do with pause()? Web search talks about handing execution off to another thread but that doesn't seem to apply to Prop C.
#include "simpletools.h"
int main(void){
while(1){
print("hello");
pause(0);
}//while
int main(void){
while(1){
print("hello");
pause(0);
}//while
Maybe deep below that getting ticks operation there is a division which makes /0. Go figure.
Sorry, couldn't resist: "Give me a 'Hello', Vasili. One 'Hello' only, please."
Of course one could say "they should just learn what waitcnt does and how the propeller works" but then... I think that ruins the point of calling a standard function called "pause".
void pause(int millis) { int time = getcnt(); while( millis-- > 0 ) { time += MILLISEC1; waitcnt(time); } }... you can have delays up to 2^31 milliseconds and 0 will just immediatly return from the function. (It's not tested and you need to define the constant MILLISEC1 with the clockticks for 1 millisecond.)Andy
Andy
Ah! You're right!
