Sending keyboard data to a PC
Hugh
Hi,
I have been looking through the Human input section of the Obex looking for an object I could use / modify to be able to send keystrokes to a PC. Nothing jumps out as a possible.
Is sending keystrokes something that anyone has ever attempted or with which they have succeeded?
Hugh
Hugh
I would like to connect a Prop to the PS2 interface of a PC and send keystrokes to it so that the PC thinks a keyboard is typing it.
Hugh
More detailed: as you can connect a keyboard to the ps2 connector of different propeller boards, the protocol should be simple and part of the demo software. (IIRC full duplex serial does the job).
So if you send the key codes from a propeller, it should work!
