TDS Sensor to Propeller
I'm looking to interface with a TDS (Total Dissolved Solids) sensor http://www.eseasongear.com/hmdispdusepr.html. I would like to us a simple RC circuit and counter to read resistance / conductance of the water if possible. I knew I couldn't use straight DC for the reading and the reason (I thought) was if I used DC the probes would start to deteriorate due to electrolysis. As I have read more the inductance needs to be read from a 1khz or greater signal to keep from breaking down the molecules in the water. So does anyone have thoughts on how to go about this with a counter or two?
My current setup has the TDS probes tied to two pins of the Propeller (with a cap and a current limiter). I take one reading with Pin 1 attached to a counter and Pin 2 set to Vss then the next reading with Pin 1 set to Vss and Pin 2 attached to the counter. This works I do get a fairly stable time reading that appears to vary with the quality of water but before I start down the road of calibration I want to address the 1Khz requirement. Is there a counter mode I'm missing that may help me here? This has to be AC cant be pulsed DC.
kwinn, thanks for your post. As I said in my original post I'm already driving the pins of the probe in opposite directions with a counter counting the time for a cap to discharge. I don't see the need to write this in PASM I would think I could easily achieve 1KHz with a counter and SPIN.
Asked and answered. Sorry to waste anyone's time.
