Proper way to handle 3-4 fullduplexserial instances
Newbie here...
I am working on a project and have a need to communicate with three (at the moment) serial devices that will each be running in their own cog. I see in the OBEX there is a four port FDS and wonder if that is the way to go.
One device is a serial GPS which I want to update with once a second. The second device is a serial touch screen. Third device is a serial communications receiver/transmitter. I also have a DC motor with built in quad encoder which will be read from on occasion to tune a HF motorized antenna..
Is the four port FDS the way to go or is there a better way??
Thanks for reading..
Mike B.
Mike B.
All the devices are running at 9600 so I should be good to go then.. I love these forums.......
Mike B.
