Sharp IR Sensor with Prop BOE Board
 NWCCTV
NWCCTV
                    Can the Sharp IR Sensor, http://www.parallax.com/product/28995 be used with the ADC on the Prop BOE Board?
                             NWCCTV
NWCCTV
Yes. The PropBOE (and the Propeller Activity Board) use a 5V analog to digital converter. You'll need to take a look at the datasheet for the sensor to see the relationship between the voltage and distance. IIRC the voltage goes down as the distance to the object increases.
I thought I was experiencing a bit of D
Is there a reason you're opting for the Prop BOE rather than Propeller Activity Board? Both are excellent, and the BOE has some additional features that might be useful (built-in mic, attached video connector), but the PAB is about third the price.
If you go with the PAB, I'd personally stick with the ADC chip it uses, which happens to interface via SPI. That'll allow you to run Activity Board code libraries without revision.
@Duane, sorry about the dejavu. just goes to show where my mind is. I totally forgot I even started that thread!!!
