I can see the data stream on the debug screen and need to capture about 5 seconds worth then average it. and send the result to an LCD
I will try to see what i can do with WRITE AND READ
Depending on the number of bits appearing in the 5-second window, you might consider streaming the data into an array. Then push that set of array data in EEPROM for future post processing.
If you can create a 16 bit reg (ALU and another GP Reg to catch the carries) it would be possible to sample every 80ms for 5.12 seconds to capture 64 samples. If you add each incoming sample to a 16 bit register (or 2 regs plus housekeeping) every 75ms to 79ms within an n =1 to 64 loop, you’ll have a total in the reg pair. Now rotate right shift the register by 6 places and viola there’s your average (almost). A right shift 6 is the same as dividing by 64. You might need to left shifted the carry reg 2 and OR with the lower reg for the average. Don't wrap around LSBs, they need to go into the bit bucket.
The wait 75ms to 79ms will depend on how often your samples come along and how important it is to be right on 5 seconds. Whether you sample for 4.8 seconds or 5.3 won’t matter as long as you have 64 samples to divide by 64. Simple, accurate and no memory would be involved.
My disclaimer-- I've never tried this and never worked with a BS2---
Dom..
If you're trying to deal with data in real-time I would not recommend using EEPROM since it has a limited write-cycle lifetime. Depending on how much data you're talking about you could store it in an array and average the array. Even so you have a total of 26 bytes of RAM available for variables on the BS2, so if this data is larger strings you may have to use a BASIC Stamp Model such as the BS2p series. Can you describe what the data looks like and what information out of it you're looking for?
I was asking about the number of samples in your 5 second sampling interval, not the serial data rate. I went to the datasheet for the sensor to find out that the samples are provided in six character groups with an "R", then 4 digits, then a carriage return character. Each sample ranges from 0000 to 9999 which would fit in two bytes. These samples are sent about one every 120-150ms which comes out to about 40 samples in a 5 second interval. Your best bet would be to use a Stamp model with scratchpad RAM like any of the BS2p series and store the samples in the scratchpad RAM using GET/PUT. The BS2 Stamps are marginal in receiving serial data at 9600 Baud, but the BS2p series are faster and should be fine at that data rate. You'd use the SERIN formatters to wait for the "R", read a 4 digit decimal number and store it in a 16-bit variable, then accept and otherwise ignore the carriage return.
SERIN <pin>,<Baud code>,[wait("R"),DEC4 sample]
The PUT statement can write a single 16-bit value as two bytes
PUT <address>,WORD sample
After reading 40 samples, your program can go back and process the saved values. You could compute the max and min for the 40 samples "on the fly" as well. Remember that the PUT address has to be an even number since each sample takes two bytes to store.
If you are using an original BS2, I think it would be fine to keep the average, min and max computed on the run in ordinary RAM variables. No need for an array. Something like this:
' {$STAMP BS2}
' {$PBASIC 2.5}
idx VAR BYTE
range VAR BYTE
accum0 VAR WORD
accum1 VAR BYTE
mymax VAR WORD
mymin VAR WORD
baudmode CON $54 ' 9600 true
DO
accum0 = 0
accum1 = 0
mymax = 0
mymin = 9999
SERIN 1, baudmode, [wait(CR)] ' sync with the stream,
FOR idx = 1 TO 32
SERIN 1, baudmode, [DEC range] ' capture 32 decimal values
accum0 = accum0 + range ' average
IF accum0 < accum1 THEN accum1 = accum1 + 1 ' double precision
mymax = mymax MIN range ' track min and max
mymin = mymin MAX range
NEXT
range = (accum0 >> 5) + (accum1 << 11) ' double precision divide by 32
DEBUG CR,"average=", DEC range
DEBUG " max=", DEC mymax
DEBUG " min=", DEC mymin
PAUSE 1000
LOOP
The DEC modifier waits for decimal digits, so it will bypass the "R" at the start of the string and it will close with the CR at the end of the number. At a sample rate of 6.67 Hz, 32 samples take 4.8 seconds.
I think the DEC modifier by itself can work at 9600 baud. Here there is no WAIT or SKIP modifier in front of the DEC, so no slow call back to the interpreter. It it doesn't work, there is another approach using the STR modifier that definitely will work.
An alternative to a straight average would be a low-pass filter. The Maxbotics sensor itself lowpass filters the streaming data.
Or are you asking the "how-to" on grabbing a serial stream and stuffing it into memory?
Dom..
' {$STAMP BS2} ' {$PBASIC 2.5} idx VAR BYTE range VAR BYTE accum0 VAR WORD accum1 VAR BYTE mymax VAR WORD mymin VAR WORD baudmode CON $54 ' 9600 true DO accum0 = 0 accum1 = 0 mymax = 0 mymin = 9999 SERIN 1, baudmode, [wait(CR)] ' sync with the stream, FOR idx = 1 TO 32 SERIN 1, baudmode, [DEC range] ' capture 32 decimal values accum0 = accum0 + range ' average IF accum0 < accum1 THEN accum1 = accum1 + 1 ' double precision mymax = mymax MIN range ' track min and max mymin = mymin MAX range NEXT range = (accum0 >> 5) + (accum1 << 11) ' double precision divide by 32 DEBUG CR,"average=", DEC range DEBUG " max=", DEC mymax DEBUG " min=", DEC mymin PAUSE 1000 LOOPThe DEC modifier waits for decimal digits, so it will bypass the "R" at the start of the string and it will close with the CR at the end of the number. At a sample rate of 6.67 Hz, 32 samples take 4.8 seconds.
