Novel Solutions Unveils New Invention, New Forum, And El Cheapo Progress — Parallax Forums
idbruceidbruce Posts: 6,197
edited 2014-12-09 07:41 in General Discussion
Hello Everyone
After several brief chats with Ken and cooling off a bit, I am back to posting, however I will no longer being doing any serious documentation here. I will instead be posting brief news updates that may be of interest to some of you, which will link back to my new forum. The forum is pretty empty at this point, because I have been pretty busy with El Cheapo, but occassionally, when I can find the time, I will try to sit down and do some serious documentation.
One of the items that I will be covering in the future within the Novel Solutions Forum, is an in depth discussion of one of my new inventions. I was initially contemplating filing a patent on the item, herein disclosed, but I came to the conclusion that some of the prior art came pretty close and that it would be an uphill battle, with the added downside that the market is probably pretty small. That being said, what I am unveiling is a highly accurate Manual Circuit Board Driller, for those that cannot afford expensive equipment, but still produce their own PCBs.
This circuit board driller utilizes a webcam to produce video of the bottom side of a PCB, with a USB port connecting to any handy PC having the webcam software installed. To begin using this device, the camera is first aligned to the 1/8" bearing within the overhanging arm, with a video overlay. Once aligned, the PCB holes are positioned using the same video overlay. The board is held firmly in position by two rubber vacuum caps. With a hole properly aligned, a hole is made by using a PCB drill bit within a pin vise. The common 1/8" PCB drill bit shank revolves within the 1/8" bearing, within the overhanging arm, to keep the drilling very accurate, however, drill sizes are limited to a size of 1/8" maximum. The driller also has an accurate fence, which can be adjusted by a screw, located at the rear of the device. This fence is very handy for drilling holes that are aligned, such as for IC chips. And although it is not very useful, but it may be for documentation, the device also has a pushbutton for taking a snapshot of the area within the cameras view.
As mentioned, I currently do not have any documentation on this project, but I am sure I will have a nice write up about it in the future, within the Novel Solutions Forum. To access this new forum, go to: http://www.novelsolutionsonline.com/cgi-bin/forum/Blah.pl. You can also access the forum through the Novel Solutions website, which is located at: http://www.novelsolutionsonline.com/
As also mentioned, I have also been doing a lot of work on El Cheapo (my Propeller powered 3D printer project). At this point, the project is definitely ready for some testing and programming, but I have several odds and ends that I want to finish first.
In the photos below, you will see the new invention, as well as progress that has been made on El Cheapo.
EDIT: IT is noteworthy to mention that the collars must be removed form the PCB drill bits before use.
    edited 2014-12-08 13:22
    Bruce, very good to see you back.
    I think all your previous posts have been very informative.
    Look forward to more.
    Jim
    edited 2014-12-08 19:22
    "You're not allowed to read messages on this board."
  • idbruceidbruce Posts: 6,197
    edited 2014-12-08 21:28
    @Publison - Jim, thanks for the kind words. I am hoping that you will continue to find my documentation informative and helpful.
    @Heater
    Visitors should be able to read all messages, but they must register to make posts. However it may be possible that I made a mistake with setting some permissions. Which board gave you that message?
    edited 2014-12-08 21:33
    The CNC one, and I got the same message.
    Good luck with all that Bruce.
    edited 2014-12-08 21:54
    Wouldn't you know it? On the day that I announce the new forum, the web host trashes my site
    EDIT: It is working now, but a few minutes, all the images were gone.
    edited 2014-12-08 22:06
    @Heater and potatohead
    Thanks for the heads-up.... My bad.... I missed one of the permission settings for that board.
    edited 2014-12-09 01:20
    I get that error on try to read General Discussion.
    Something is up with that forum. It never finishes downloading.
    ....eventually it times out and there is the error in the dev console:
    GET http://64.29.146.68/track/ctin.php?t=1418117043742&custnum=4786c26a70dfb0b2…Content%20Decryption%20Module%3BNative%20Client%3BChrome%20PDF%20Viewer%3B net::ERR_CONNECTION_TIMED_OUT
    Some sort of evil tracking system by InternetNamesForBusiness.com
    Looking into the code we find some more tracking:
    <script type='text/javascript' src='https://count.carrierzone.com/app/count_server/count.js'></script&gt;
    <script type='text/javascript' src='https://count.carrierzone.com/app/count_server/count_piwik.js'></script&gt;
    Well, I guess that's all just the everyday web snooping we are all used to.
    edited 2014-12-09 03:55
    Heater
    Very Interesting!
    For one, the web statistic service that AT&T web hosting uses really bites. In fact, I had them completely sever that service from my other web site. It took me a while to track that one down as a culprit of slow downloads.
    I would imagine that could be a problem with this web site as well. However I will have to look at the forum script and see how it obtains forum statistics.
    edited 2014-12-09 06:00
    AT&T's Web Analytics has been removed from the Novel Solutions web site and the forum now appears to load much faster. Additionally, I must admit that there were a few errors in the permission settings of the forum, but the errors should now be fixed.
    That fixed it.
    "...diehard IE fan...". It's almost worth signing up to have a bash on that concept :)
