sound frequency sensor - audio frequency sensor
Team
I would like to list for a frequency of sound. this sensor looks good. http://www.embsysstores.com/sound-frequency-sensor.html
does anyone know how to use it with Prop C?
your help is appreciated.
thanks , Mark
thanks , Mark
At a guess that uses a NE567
eg http://www.dl2lto.de/gif/HB_ZB_1.gif
That gives a static on/off type signal, that should be easy to use in Prop C - just test the pin level.
A series R may be needed for 5V -3v3 handling.
What specific frequency do you want to listen for, and what duration and stability and noise floor does that have ?
