MIDI Controller - BS2
Using an old (2003) Parallax Midi documents (Gettin' MIDI With It - Jon Williams) I setup a MIDI out circuit on my BS2. I check the results using a PC midi interface and program call MIDI-OX (midi monitor). Results are good. I can press a button and play a Midi note on the PC synth. But (here is my dilema) when I connect the same Stamp to an external Midi module it does nothing. ?????. I have test the Midi Module with a Midi Keyboard and it works. Any ideas why the same cicuit/code work in one instance and not in the other?
Already test wirh a 9v cell and a Wallwart adapter, I though the external Midi module will need more current...no difference.
PRPROG
PRPROG
Yes, I am the artist formerly known as Jon Williams.
PRPROG01,
Try these links:
http://www2.yamaha.co.jp/manual/pdf/emi/english/synth/TX81ZE.pdf
http://the-all.org/tx81z/
You might also try tweaking the baud rate setting used.
Long term, I suggest a switch to the Propeller -- it runs faster, can generate serial data in the background, and the baud generation is more accurate, too.
Yes I used 220 ohms resistors on the midi out connector. For the BS2 I am using MidiBaud CON $8000 + 12 . Which other baud rate can I try?
Welcome! Happy to help.
The "the-all.org" link even has the service manual about midway down the page. :thumb:
Ok. I will give it a try.
Thanks.
I activate a capability on the MIDI-OX PC program to route the MIDI IN to the MIDI OUT of the M-Audio (Midi) interface. I connect the Midi out to the MIDI in to one of my modules. Now the Stamp can send the midi messages correctly to any MIDI device . It works with the Yamaha TX81Z or the Roland U-220 . Of course this is not how I need the Stamp to work as a MIDI controller. It must work without the PC.
It got to be the MIDI circuit, but what could it be? Any suggestions? (already using the Stamp with a Wallwart adapter.
PRPROG
First of all, thanks a lot to JonnyMac and davejames for taking the time to answer my post. JonnyMac you got the answer on post#5. One of the resistor was not 220 ohms ...it was 2200.When I took one of the resistor , the one 220 ohms, the circuit starts working only with the Casio keyboard (which means Casio is not that strict on the Midi electrical requirement) . Yesterday I notice the error, set both resistors to 220 ohms and it works like a charm on all my Midi devices (Yamaha, Roland, Casio). Sorry for not noticing this before.
Very glad you got that sorted; sometimes it's tricky to differentiate color bands on resistors. It seems like every time I pop into All Electronics I pick up another hand-held magnifying glass just so I can verify things.
Have fun with with project.
You're very welcome.
Thank you for posting the resolve. It's always nice to know "what happened".
We all know that Jon does not put out software that does not work.:)
I get resistors mixed up all the time, after 40 years.
Next weekend, send some stuff to my Roland G-1000 and Kurzweil K2VX.
So you're the guy who buys up all the good stuff before I can get there!
I live just 15 minutes away (by car), so there's no reason for me not to pop in frequently. What I really appreciate about those guys is that they're open on Sundays -- I have made many "emergency" runs over there when I needed parts on a weekend.
That's kind, but I am human and have slipped once or twice. The MIDI stuff was old, but I had run it through an external keyboard. I recently made a small MIDI adapter board for a friend to use with Propeller projects. It's the same circuit with a couple small gates to bump the 3.3V to 5V.
http://www.ebay.com/itm/USB-Digital-Pen-Video-Microscope-Endoscope-Magnifier-Otoscope-Webcam-tool-Camera-/200900528519?pt=LH_DefaultDomain_0&hash=item2ec69ac987
