55-Cent Li-Ion 14500 Cells: Too good to be true?
Maybe. Title says 2X for $1.09:
http://www.ebay.com/itm/2X-3-7V-1200mAh-14500-AA-Akku-Wiederaufladbare-Batterie-Lonen-Li-ion-Battery-SU-/201210903495
I asked the seller to confirm. Half the price of others. I know they will be half the capacity claimed, but I'm building lots of projects these days (3 bots yesterday!) and these AA-sized batteries are perfect for demos. I'm using up my existing supply of 14500s. I build them inside projects (one cell) and add a USB charger board, and 5v booster board if needed, works great.
Power Input: DC 11 - 18Volt
Circuit power : Max. 50W
Charge current range : 0.1~5.0A
Current drain for balancing Li-po : 1200mAh/cell
NiCd/NiMh battery cell count : 1~15cell
Li-ion/Polymer cell count : 1~6series
Voltage: 3.7 V
I can't imagine any Li-ion/Polymer cell that can hold up for long to 18 volts DC at 5 amps. And I don't see why the mention of NiCd/NiMh.
My gut feeling is that the Seller is clueless about batteries and English.
On the other hand, the so-called AA size Li-ion cells are a wee bit longer than the AA and don't really fit in a standard battery holder. It may just be that the manufacturers are so over-stocked with these odd sized cells that they need to offer them cheaply. (I have a few.)
Unless you own a flashlight or other device made specifically for this cell, it can be a nuisance to work with.
If you do buy, use a Lithium charger that is made for it and DO NOT try to DIY at 11 to 18 VDC.
Will advise!
Kind of like the Chinese cap inside a cap (see last photo)? http://www.discovercircuits.com/dc-mag/Issue_4/rants-raves.htm
The previous Li-Ion AA cells erco made me buy weigh 16.20g each. An Eneloop AA weighs 25.95g.
That must be a(nother) gross error in the listing. Two years ago, a 14500 seller sent free AA-sized dummy cells afterward, just a short circuit, a tube with a conductor inside, to help prevent item damage by installing too many 4V cells. Even those hollow lightweight "nothing inside" cells weighed 5 grams.
At 55 cents, I might have to open up one of these 14500s to see what's inside.
@Duane: I knew I could count on you, Dawg. The first (OK, second after me) guy in the pool!
http://www.ebay.com/itm/4-pcs-Pack-Dummy-Battery-AA-2A-Size-Conduct-Conductor-Electric-Current-US-Stock-/131317793051?pt=LH_DefaultDomain_0&hash=item1e9326811b
+1 for the Chinese "factory reject" sellers!
I even found the guy selling cases at 10 for $4 so I won't have nekkid batteries sitting around waiting to catch fire...the plastic case should add a nice accelerant (and fumes)!!
http://budgetlightforum.com/node/27683
Neither a borrower nor lurker be!
So far, the best offer is from BGmicro - genuine Sanyo 2000mah 18650 cells for $1.75 each.
http://www.bgmicro.com/ur18650f-2000mah-rechargeable-lithium-ion-by-sanyo.aspx
**Throws a bolt with force enough to spall something.**
And I mentioned that one earlier this year because the batteries in question are exactly like the ones we use on our Parallax stuff.
So is that good or bad?
Hello!
As with everything else in this mad business, it depends. The big problem is one of, these rechargeable batteries that BG Micro is selling are all of a certain well known number in the battery catalog.for them.
It therefore follows that they should all have the same chemistry inside them.
For example on the BOE board there are the 9V snaps. We can attach any variety of 9V battery there, and they will all work the same regardless of name brand. (Except probably the Costco specials.)
However since I've not worked out a real need for the things, I've not had a reason to buy any, and of course you will note that he's no longer selling a cluster of them and the charger.
It works okay, weight 22grams and is labeled at 1200 ma and 3.7 volts. Certainly wasn't 55 cents.
My only problem with this is that any excessive discharge below 3.3 volts or so will cause sudden death.
These need a low voltage cutoff circuit to avoid suffering from useless after one run.
Erco's point about needing to have a real need for these is very valid. They are nice in an LED flashlight that already uses the same and shuts down before damage. But that is about it.
I charged mine on a 18650 charger that has adapters for smaller cells
If you use a 14500 without protection, you merely have to add a protection board to the cell.
Of course, you take your 55 cent cell and add a 99 cent board to get the complete package. They you are in great shape.
http://www.all-battery.com/protectioncircuitmodulepcbroundfor37vli-ionbattery2alimit-32133.aspx
Each cell was in a nice individual ziplock antistatic bag. This could mean either:
1) Sellers are getting more responsible about battery shipping safety, or
2) Cheap cells are known to leak electrolyte.
No leakage yet!
If the money wasn't so little, I'd have my credit card company revoke the transaction.
I bet it was their special "Buy 2 - Get 1" sale!!
I just got my package and opened it and found 1/2 the expected batteries. Time to contact the seller and review the meaning of "2x"
Yesterday I received half the batteries I ordered. I just sent the seller a message asking for the other half of the order. I had ordered 20 cells.
I don't understand how so many sellers can offer free shipping but charging $29 to ship an AA cell is harder for me to understand.
$29 shipping, hmmm. Did we ruin the deal for everyone else?
http://www.ebay.com.au/itm/251641461799?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
I also ordered a single and a dual charger (used to then charge phones etc). Here is the single
http://www.ebay.com.au/itm/221566559992?var=520422893008&ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
So far the chargers work great (you require a 5V source - I have a 240V to USB power plug adapter that works fine for this).
You also require a USB to microUSB cable.
Not sure yet whether the cells really have 6000mAh, but at this price for what I want, they seem fine.
I have bought them plus some motors for my grandkids to play with to get them interested in such things.
BTW Shipping doesn't bear any relationship to cost. You should add the goods price plus shipping to work out if the price is good.
http://www.ebay.com/itm/251641461799
Sure, economy shipping= a coach seat for each battery on a discount airline.
