433Mhz to xbee conversion
I currently have a working project that uses the 433Mhz transciever and I would like to convert it to use the xbee. Are there any easy solutions to code conversion and pin changes? I am limited on pin changes because it uses the propeller mini as the processor.
Below is a link to programming an XBEE on a Propeller ActivityBoard. Even though you are not using the ActivityBoard, the code should be pretty much the same ( you will just need to change the pin assignments ).
http://learn.parallax.com/propeller-c-simple-protocols/full-duplex-serial
Good luck!
