Using AC instead of DC to power LED's
So I was just watching a show on Science Channel that demonstrated how strands of LED Christmas lights are made. First, for some reason they only used resistors on 1/3 of the 60 LED's which are bright white. No explanation as to why only 1/3. Next, they did not show anything about what is used to convert the LED's to be able to use AC current instead of DC. So, there in lies my question. If I want to make a strand of LED's what would I need to use in order to run them on AC voltage?
Or you can Google image search "led string schematic" and let the sparks fly
It was very bright initially. I ocasionally plug it in for reference, and check the current. It drraws very little current. It seems to have gotten dimmer (after a couple years?). I never leave it on too long as I'm afraid of 110 volts.
I think I should have had a resistor and capacitor circuit, but at the time I figured I was better off not messing with mains circuits, so I never figured out the proper capacitor values, to resist the temptatio to keep messing with it.
That is similar to what I looked at previously. How would we go about adding more LED's , get flashes from both the up cycle and down cycle, and eliminate the non-LED diode in the rectifier circuit?
I looked at this:
http://www.electricaltechnology.org/2013/03/230-v-ac-main-operated-led-powerful.html
but I don't have the backgound to mod the circuit for more LED and or 110 volts. I just added more LED's until the voltage drop was about 110 volts, and onitted the capacitor. Which is probably why it getting dim quickly.
I'm in the same boat. A friend of mine is an electrical engineer and explained how this circuit works (several years ago) but I forget the details.
I do remember it is based on capacitor reactance -
http://www.electronics-tutorials.ws/filter/filter_1.html
http://electricianeducation.com/theory/capacitive_reactance.htm
Not that the chinese manufacturers would use it. They just nominally add up all of the voltage drops and resistors in series for a little over 120V and call it good. Double the string length for 240V. added bonus don't worry about lopsided power factor with all of the LED's facing one way, but still throw "energy efficient" and "lasts 10000 hours" on the box and change the company name every 2 years.
LOL, but likely to be very true. Sometimes it pays very well to put a lot of distance between yourself and your customers.
On the other hand, there is a lot that can be learned about electronic basics by building a good string of 120VAC Leds. So please focus on the good solution and try to come up with an answer that we can all learn from.
A full wave 120VAC current regulator? Does such a thing really exist?
I researched using series leds powered from 120VAC to build a traffic light/color organ for my kids years ago. Pretty sure I still have all the notes, calculations, and schematics somewhere. I can dig them out and post them if anyone is interested.
