Cheapest Windows Based Propeller Dev Platform found at Office Max
frank freedman
Well maybe not a Pi or Rubix A10 (unless you add in Keyboard, mouse, and monitor)
A few days ago, my Nexus7 met an untimely end. Thursday I found its replacement at OfficeMax. They had a HP Stream 7 tablet on sale for $99.00 with Win 8.1 on it. Turns out it is NOT an WinRt system. So all the USB stuff works as it should for serial comms, USB to hard wire network (need that to run some stuff on CT systems and PACS/network checks) and USB to parallax products such as the C-3, Quickstart and USB proto-board. On the down side, it is useful to have at least a Bluetooth mouse (and maybe keyboard) to make life easier with the IDE, but it does all work. And the price is right. So far a real keeper as tools go. Just need to find a good X-sserer for it without having to resort to Exceed.
I have found a lot works reasonably with this: https://www.starnet.com/xwin32/
You can do short, 30 minute sessions at no cost.
Sounds from #1 like it works fine.
store.HP and Officedept are suitable vague on the actual details, but google finds this
http://www.amazon.com/HP-Stream-Windows-Includes-Personal/dp/B00NSHLVD2
which says OTG, and also mentions
"I could transfer up to 19MBps from tablet USB to tablet microSD card"
so that looks like a 480MBps compatible USB port.
Indeed. "OTG" is the keyword anyone should use that is looking for similar adapter or functionality.
http://www.microcenter.com/product/439773/7_Tablet
full size USB 2.0
Impressive, I found this expanded comment on another forum
["it's model number is "TW700", with a SKU of "468421". This series of tablets feature a Bay-Trail T Quad-Core processor, Windows 8.1 with Bing, [B]one full-sized USB 3.0 port[/B], and a two-device license for Office 365. The newsletter suggests that the device has 1GB of RAM and 16GB of secondary storage space. This tablet is available only in-store, and is limited to 3 per customer/per household(presumably)."]
So just 16GB, but does USB 3.0 so adding a USB HDD is maybe an option (with some power supply 'T' ?)
Edit: Here's the review... http://winsupersite.com/mobile/hp-stream-7-first-impressions
Winbook was a brand started by Microcenter I guess as: http://www.winbookcorp.com/
NOTICE: This site is no longer being updated. Please visit www.microcentertech.com.
David Carrier
Parallax Inc.
I know some people who like this one - http://mobaxterm.mobatek.net which can be used for free.
Reads PDF doc files, including very long ones with lots of graphics, responsively and without hesitating or locking up -- check
USB peripherals, especially serial ports, work -- check
All our serial diagnostic and downloading tools work -- check
It's lighter, more rugged, and a quarter the cost of a laptop to do those things -- duh
It boots in like five seconds flat, and doesn't BSOD if you say unplug the USB serial dongle while it's asleep like my netbook does -- check
Because it's "crippleware" 32-bit Windows 8, it actually runs 32-bit software (of which we have several packages we critically need) that won't run on normal Windows 8 -- HELL YES CHECK
You can remote into it from a real computer with TeamViewer and treat it like a real computer -- HAHAHAHA yep.
This thing single-handedly solves four or five nasty long-standing problems we've had more cheaply than the other solutions we've looked at for any ONE of those problems. Today I got a bluetooth keyboard for it, I didn't get a mouse mainly because the only one the store had was $60, and I anticipate it mostly replacing my EEEpc which this thing makes look like an ocean liner.
MS & Intel must be worried as HP must be getting the s/w and chips for next to/or nothing!!!
Thanks for the list, impressive & the 32 bit aspect is quite revealing.
Did you check any USB Dongles ?
I do think the 32-bit thing is a particular strategy for the mobile market; the Stream has 1 gig of RAM, considered underpowered by today's standards but adequate for a lot of practical work. You need 64-bit for more than 2 gigs RAM. (Yeah 32-bit should go to 4 gigs, but some stuff stupidly uses signed math.) So I think the 32-bit Win 8 was a "crippleware compromise" to provide a version they could offer cheap/free so as to compete with Android and iOS, without threatening their "real" desktop OS market.
The ironic thing is that not only does this make the Stream MORE functional than a real laptop, the very features of Win 8 that are so maddening on the desktop actually work here because, well, it's a tablet. This has actually given me a new appreciation for Win 8 as a table t operating system; in some ways it's much better than Android. It's really too bad they had to create such a bad taste by shoving it down our throats on the desktop too.
http://www.neweggflash.com/Product/34-734-009?nm_mc=AFC-DealnewsFlash&cm_mmc=AFC-DealnewsFlash-_-na-_-na-_-34-734-009&utm_source=AFC-DealnewsFlash&utm_medium=Affiliates&utm_campaign=na
Edit: never mind, it's not a true keyboard dock.
http://www.newegg.com/Product/Product.aspx?Item=N82E16834757020
The specs almost match the HP one, but it has a bigger battery and thicker case.
— David Carrier
I finally did find an application that chokes the Stream, because it has several hundred megabytes of dependencies and is an almost heroic example of lazy bad design, so it manages to use up all the RAM. It does run but it's obviously swapping stuff to the flash drive like crazy and taking minutes to accomplish user interface state changes. We thought that was a problem since we have a tech who uses that app until we realized it was a new version, and when our tech updated his netbook to the new version it choked too.
It's really amusing to use TeamViewer to remote control the pad from a real computer.
P.S. I feel like I need to take a bath after saying something is under-powered because it ONLY has a gigabyte of RAM. It doesn't seem like all that long ago when all the university and government computing centers in the world didn't add up to a gigabyte.
Will that work for you.
http://www.tlbhd.com/asus-eeebook-x205ta-19242/
Yep, This is what has become of my BB Playbook keyboard. Not shown here, but ..... Just the right size for the generic case I stuck the Stream into. Seems no one has a stream 7 specific case out for it.
