BS2pe + 2 line scan cameras, plus some extras ...
Okay, so I've got an application here that I'm looking at using a BS2pe motherboard for.
Short version, I'm applying a coating to a thin film, and I'd like to use a BS2pe to monitor coating thickness in 2 ways. First, I'd like to have 2 linescan cameras (there are 2 strips of film getting done by a single machine). The cameras will monitor the average gray value in their field of view. The trimming of the machine to increase or decrease coating thickness is by means of a 0-10 VDC signal. As an additional data point, I'd like to use an LED + photoresistor combo on each film stream to monitor the light transmission properties. Last, I'd like to log the data to an SD card or USB stick.
Is all this feasible from a single BS2pe, or would I need separate units for each camera? Can I even effectively do data logging with them - all the SD card setups that I saw in the store were for propeller only?
I'd rather not go up to a propeller if I can avoid it - I've got a fairly decent base of experience with BS2's ...
Frankly, this sounds complex enough that you'd be better off using a Propeller to begin with. You wouldn't need a separate datalogger and the Propeller can do the ADC and DAC directly (with a few passive components). There's plenty of sample code in the Object Exchange for ADC, DAC, datalogging to SD card. I don't know what the camera needs, but that shouldn't be that hard.
I did look at getting a propeller developer board, but I guess I'm a little intimidated by the added complexity over PBasic, but there's enough areas in this project that are likely to experience mission creep that I may have to go that way. Too many people are having too many brainstorms, so to speak ...
My cycle time on this can be pretty slow - I have no huge speed requirement. If I'm making a correction every second or two then I'll be fine. (The process isn't that sensitive, and right now it might go hours or days between corrections, which are all done manually based on weighing samples and such.)
The camera that I'm looking at using is the TSL1401, since it's already set up for the BS2pe motherboard. I guess the big question is on the subject of the expandability - I only see connections for 2 daughterboards on it. How many of them can I daisy chain together?
I'll take another look at the Propeller stuff too.
Okay, then, so 2 daughterboard connectors means 2 linescan cameras, and I can use the un-used pins for the photoresistor input .... but if I need control output (or anything extra) then I'm probably going to need 2 BS2pe's instead of just one. Or one propeller, I guess.
Am I reading this correctly?
