Question about Tachyon — Parallax Forums
David BetzDavid Betz Posts: 14,530
edited 2014-11-10 08:48 in Propeller 1
I've been playing with Tachyon and its interactive capabilities a little lately and was surprised about some behavior I saw. In particular, I defined a word, used it in a second word, and then redefined the first word. I thought that the second definition would pick up the new definition of the first word but that doesn't seem to be true. I know it is normal for previous code to continue to use the old definitions in traditional Forth but I thought I remembered Tachyon handling this differently. Am I mistaken?
Here is a simple example. The word "bar" makes use of the word "foo". The first example works the way I expect but when I redefine "foo", "bar" still refers to the old definition.
: foo 3 * ;  ok
: bar 100 foo ;  ok
bar . 300 ok
: foo 4 * ;  ok
bar . 300 ok
Is this expected behavior.
    edited 2014-11-09 05:27
    WTF?
    With Peter's goading I was having another play with gforth today. Now you tell me one of my fundamental assumptions was wrong:
    : cat 42 . ;  ok
    cat 42  ok
    : dog cat ;  ok
    dog 42  ok
    :cat 100 . ;
    : cat 100 . ; redefined cat   ok
    dog 42  ok
    Call me stupid for thinking that "redefined" meant, well redefined !!
    How is one supposed to cause the definitions in use by other words to be updated, I guess there is a way ?
    edited 2014-11-09 05:40
    Words in Tachyon are compiled just like any other Forths. Compiled words reference other pieces of compiled code, and not the name in the dictionary. Once a word is compiled it doesn't matter if a new word is defined with the same name.
    It is possible in some Forths to redefine the code that a Word points to using the IS word. Words that allow redefinition using IS must be defined with the DEFER word. The DEFER word is used to create something similar to a function pointer.
    edited 2014-11-09 05:54
    David Betz wrote: »
    : foo 3 * ;  ok
    : bar 100 foo ;  ok
    bar . 300 ok
    : foo 4 * ;  ok
    bar . 300 ok
    Absolutely as bar compiled to point to foo via the vector table. When you create a new definition with the same name it doesn't try to do anything fancy, just simply do, rather than guess. Now if you perhaps named the new word foo2 so that you could still reference the old word too then you could get bar to actually execute foo2 instead of foo with:
    REVECTOR foo foo2
    So the vector for foo will now point to foo2 so that the code for old foo is now orphaned (no vector points to it) and instead points to the code for foo2.
    The simplified bytecode for these definitions helps to understand this, here each line except the labels is one byte.
    foo: <----(CALL VECTOR 240)
    3
    EXIT
    bar: <----(CALL VECTOR 241)
    BYTE
    100
    XCALL
    240 (foo vector index) ---> (16-bit pointer to foo)
    EXIT
    foo2: <----(CALL VECTOR 242)
    4
    EXIT
    So if you change vector 240 to point to foo2 then bar will call foo2 via vector 240.
    The XCALL can be one of 4 general CALL opcodes (XCALL,YCALL,ZCALL,VCALL) which each lookup one of 256 vectors using the next bytecode as an index into the vector table. This scheme makes it a lot easier to write the initial kernel using the "Spin" compiler although it's not Spin but PASM or byte structures. Unlike conventional Forths which "interpret" 16-bit addresses which point to the code field, Tachyon is more like a regular CPU which reads opcodes, so that four CALL opcodes really have 2-bits of the vector address and the following byte has the other 8-bits. So there are no "code fields" as such, it's all bytecode composed of opcodes and operands.
    edited 2014-11-09 06:12
    REVECTOR foo foo2
    3
    EXIT
    BYTE
    100
    XCALL
    EXIT
    4
    EXIT
    Thanks for the explanation. I remembered the "vector" part and I was thinking that redefining a word with ":" would just update the pointer in the vector. I guess that isn't done automatically but instead requires the use of the REVECTOR word. This means, I guess, that to redefine a word and have all previous references to that word point to the new definition requires a two step process and the creation of a dummy word as an intermediate name for the new definition. Anyway, I was asking this because I'm working on my own interactive language and I wanted to be able to redefine functions and have the new definitions used by existing references and I was trying to understand how you handle this. Looks like we might take slightly different approaches.
    edited 2014-11-09 06:52
    David Betz wrote: »
    Automagically changing things is not something I just want to happen and normally there is no need for it expect perhaps when things are being tweaked, so it's no problem to specially revector something in that regard. Yes, approaches are different because Tachyon has never been about academic exercises in languages, it's always been about how to get the most out of the Prop and to do it interactively too.
    A lot of these features I don't find practical either because we only have 32K memory effectively and if it's all taken up just supporting fancy features that look good in demos then what can you really use it for when there's no memory left? For instance, when we create foo again we now also have to search the dictionary for older references. Then is this the only older reference, are there more? What do we do? Fine, there might only be a few steps and some decisions but there are a lot of things the final app will have to do and compile-time magic looks good but does the system need it and can it afford it?
    edited 2014-11-09 07:08
    This doesn't make any sense to me. You have the REVECTOR word so it seems to me it would take less space to just have the colon word always revector rather than requiring a separate word to do that. I guess that isn't the Forth way though. In any case, it seems confusing to me to have a word called "foo" that behaves differently in different contexts based on whether it was used before or after a "redefinition". Perhaps this is tied up with the Forth concept of "forget" where you can pop a bunch of definitions off the dictionary stack. The new "foo" needs to be close to the top of the stack. It wouldn't do to have ": foo" just change a vector for a word further down in the dictionary because it would mess up ordering. This explicit dictionary management is part of the Forth way I guess.
    edited 2014-11-09 11:26
    Guys,
    I can feel my brain melting again.
    I'm told that Forth has this dictionary full of words. Words are either predefined in the system, like "+", "-" etc, or user defined with the ": doSometing 10 . ;" syntax.
    Then I'm told that words can easily redefined over the command line interface (REPL) for quick interactive development.
    Now I find that words hang on to the guts of the sub words they use when those sub words are redefined with new guts.
    Please someone tell me what is going on here?
    Even in good old BASIC I can enter a new definition of line 100, for example, and my program changes exactly as I expect.
    edited 2014-11-09 14:17
    Heater. wrote: »
    Guys,
    IF youse redefine a word, the definition is the only one found from that point onward. BUT stuff that is poijnting to the previous definition is still pointing to the previous definiton. I think they call it "operator overloading" in some languages.
    But really, if you want to a functtion PRINTA that prints capitol "A" and a funtion PRINTA that prints a lower case "a": either make up your darn mind or call one PRINTa.
    If you want ot go back to the definition that already in the dictionary and edit that, don't. That's an advanced thing that you will confuse you, as you have observed. Don't eat the elephant in one byte.
    edited 2014-11-09 15:31
    David Betz wrote: »
    It's a matter of what one wants/expects/needs the compiler to do. I thought about this when I first wrote Tachyon and after running through different scenarios I decided not to do anything like that, just keep it simple. Since Tachyon uses vectors I wrote the REVECTOR word to allow me to patch and test, but it is used extremely rarely. So having a feature to foo foo sounds nice but do I need it?
    There are so many ways of doing these things but the other thing to remember is there are Forths and there are Forths, some are designed for PC environments with large resources, others are designed to run on very small embedded processors with very limited resources (in today's terms) such as the Prop. Do we want the Prop as a mere "prop" to show off a language and clever little ways of doing things but incapable of doing much more because of a lack of resources? Yeah sure, just add this RPi or maybe this memory expansion card, use up all the I/O for it, and you can emulate an address/data bus and increase code size by 16 fold, just a bit slower, but is it practical? For one off it's fun, but I'm into building product so I keep it realistic and practical, and the big thing is, it has to work and it has to perform. Isn't that the whole reason for computer languages and programming in the first place? Not just to have books published and keep university departments and courses filled.
    edited 2014-11-09 16:43
    Well, clearly Tachyon is useful to you and a few others and you've been very productive with it. It doesn't meet my expectations for an interactive language though. I guess Forth is just not for me. A bit too minimalistic for my tastes.
    edited 2014-11-09 17:24
    David Betz wrote: »
    How does a 32K Prop compare to a 64-bit WinTel machine with gigabytes of RAM ? Yes, the Prop is minimalistic compared to the PC but we leave the PC on the desktop and run the Prop where the PC wouldn't have a chance. We are talking about an O/S + language + development utilities + application ON a 32K microcontroller. That should be really really good news and I am always dumbfounded when I hear comments about comparing everything under the guise of "language" to what is essentially the desktop PC + O/S????? That just never makes any sense in the real world. How can you have a PC style O/S language running on a 32K micro? Upgrade it until it is no longer a 32K micro? Apples and oranges, not the same.
    Come on, a lot of people are still having trouble blinking LEDs on the Prop with their most excellent PC development systems yet you yourself know the state of the Tachyon O/S and how much functionality it packs in the Prop itself. You would think that this would be a big boast for Parallax that P1 can do all this? Still, they are busy pushing "learning" tools. What happens when they get beyond learning and demos and need to do some real stuff and then I wonder why would they do it with the Prop when a 50cent PIC will blink a LED just fine too? (except that they have a nice development environment on their PC).
    edited 2014-11-09 17:34
    Many people seem to use Tachyon productively and a great many more admire the amount of functionality you've managed fit into the limited resources of an unexpanded Propeller chip. However, I think it is probably unrealistic to expect everyone to drop Spin or C or C++ or PASM or Basic or whatever they are using now and jump on the Tachyon bandwagon. Sometimes it isn't necessary to squeeze the absolute most out of the processor. Sometimes enough Spin or C or Basic will fit into the Propeller to do the job. No need to learn a new language even if it does have the potential of allowing more code to fit in the limited Propeller resources.
    edited 2014-11-09 17:36
    Braino,
    I think that is a bit of a stretch.
    I have only ever seen operator overloading in languages that have an idea about types.
    For example in C++ you may define a type (class) of "Apple" and then define the "+" operator for apples to do whatever you like. Then when you write "+" in your code the actual version of plus that is used is decided by the types of the operands.
    In a similar way we have polymorphism whereby there may be many functions or methods with the same name but they each take different numbers and types of parameters. The actual version of the function that is called is again decided by the types of the parameters in the particular call.
    But really, I have been hearing for ages that a major strength of Forth is it's interactive nature and how malleable it is from it's REPL. How easy it is to redefine things from the console. Which is quite true.
    Now I find that malleability is not quite so straight forward. If not impossible.
    The question is not about printing an "A" or an "a". What if my program works fine and now I want to change PRINT so that the output goes to a different device? No can do. Or at least not as easily as I was led to believe.
    Now, I don't much care if I can do such redefinitions on the fly or not. It's not something I'm expecting to want to do a lot. But this feature did come as a surprise to me. It is not expected behaviour if you come from BASIC or JavaScript and so on. As long as I know we are good to go.
    Hmmm...seems I keep choking on the mouse every time I try to get it down :)
    edited 2014-11-09 17:46
    David Betz wrote: »
    Once again, apples and oranges. Besides if you could do the job nicely in Basic then maybe you don't even need the Propeller chip. Since I design for production this is the design choice I would make early in the piece and if it's volume then the 50 cent PIC is designed in even if it's a gruelling task to code it all in assembler. However since when has there been this expectation that everyone should drop Spin or C or C++ or PASM or Basic and jump on the Tachyon bandwagon? I can't see it happening at all and one of the main reasons is simply to do with mindsets, but if you wanted to get the most out of the Prop then I would encourage those ones to not limit their mindset, to stop comparing apples and oranges, and consider Tachyon. As they say, the proof of the pudding is in the eating.
    "Someone" mentioned malleability as if that were the standard that Forth or perhaps Tachyon should be judged by? Well once again it's how I want it to be which is what malleability is, to be able to shape it to one's needs, which I can. Someone else can go and shape it another way if they want and foo foo all they want.
    edited 2014-11-09 17:48
    I only brought this up because I'm working on another interactive language that I hope will be useful. I also remembered Peter talking about "vectors" and thought I remembered that they were to allow words to be redefined. I guess I misunderstood. As it turns out, my language can handle redefinitions of functions such that all existing references call the new definition but it can't currently handle the same level of functionality for data. For example, if you define an array, use it in some code, then redefine it, any previously existing code will still use the old definition. I was trying to decide how big a problem that is and wanted to use Tachyon as a benchmark because it is thought by many to be a useful interactive language. I didn't really mean to criticize its approach, just understand it.
    edited 2014-11-09 17:56
    When I talked about "jumping on the Tachyon bandwagon" it was in response to this comment. It sounds like you're suggesting that Parallax should forget SimpleIDE, PropGCC, and maybe Spin/PASM and use Tachyon instead since it allows more to be crammed into the Propeller.
    edited 2014-11-09 18:05
    David Betz wrote: »
    Because I never touted redefinition as any kind of desirable feature that I need anyway but while the focus is on what Tachyon is not, it then ignores what it is, which is probably a whole lot more then we have time to talk about. If foo foo style redefinition was actually important beyond looking good I would implement it and as you know that would take me less than the time it takes to respond to this thread. Also if anyone needed to cram more into the Prop then they normally could, then yes, use Tachyon.
    edited 2014-11-09 18:09
    Peter,
    That would be me of course. Such interactivity and "malleability" has been a big sales pitch for Forth on these forums for a long time.
    That is not the same "malleability". By that argument I could say that C is malleable. After all one can redefine the language anyway one likes and rewrite the compiler to compile that new version of C. Assuming one has the skill to do so. Similarly for any other language.
    My compiler writing skills only extend as far as generating very suboptimal code from a simple minded, block structured, language in the style of C/Pascal so my hat is off to you and anyone else who can define their own language and make it work.
    P.S. I do agree that such on the fly redefinition is not a lot of use. Certainly not a "must have" feature. I was just surprised that it gforth, and others it seems, did not work that way.
    edited 2014-11-09 18:11
    I have no doubt.
    Yes, it would definitely be something worth considering.
    edited 2014-11-09 18:18
    What I object to is that you seem to insist on calling any other approach frivilous or stupid. Yours is the only sensible and viable way of doing things I guess. I'm glad you are so certain of this. I always believe that there are ways to improve anything. In fact, that is why I asked about Tachyon. I wanted to benefit from any of your good ideas that might improve my own efforts.
    edited 2014-11-09 18:47
    I doubt that Peter thinks that Tachyon is the only way to program on the Prop. There are many scenarios where it makes more sense to use Spin or C, and there are some case where Forth is the best approach. It depends on the application and what the programmer is most comfortable using.
    edited 2014-11-09 18:50
    Dave Hein wrote: »
    No, I don't believe he thinks it's the only way either. I do believe he thinks it is the only sensible way and that other approaches are flawed. It must be nice to be so certain you are right.
    edited 2014-11-09 20:05
    Heater. wrote: »
    C'mon, you know that is not so. Remember, this is NOT an OS running on a workstation. Each command is a few lines of code that do exactly one thing for you, which might look like something an OS does, but its not is only that one thing and nothing more.
    Each interface is hard codeed, that how far down into the hardware we are. We are not way up at an OS level.
    Sal made standard interfaces in propforth, if you want to point to a different interface, you just plug it in and got. That is why propforth has a bit bigger memory foot print than tachyon, and runs bit slower. But that is NOT standard forth; standard forth is hardcodes the interface, since that is the hardware, and generally doesn't change. Sal designed for "plug in interfaces". Do you need fastest, or do you need plug in intterrfaces? You can ask for both, but something has to give.
    We can do thing like change existing definintions so that previously defined function are affected. But its tricky, if you don't know what you are doing you will make an error. Just avoid the the tricky stuff, till you get used to not having a full OS.
    edited 2014-11-10 00:24
    David Betz wrote: »
    I only time I use Tachyon is when I use the Propeller. That's a simple enough statement and quite correct. In some other buried post I even said that for me Forth works really well in a certain class of embedded controllers, not too small, not too big, and in fact hardly ever on a PC which is where most people are familiar with Forth and yet one I avoid because we have such glorious almost interactive IDEs in different language flavours, and in that environment I am really quite happy to program in something other than Forth. PC Forth on an old DOS machine kinda made sense, not any more.
    I am definitely no elitist, more of a pragmatist, but I know I'm quite right in respect to the Prop because as I mentioned before about the proverbial pudding, I have seen the results to confirm my "hypothesis" if you like and it is no longer subject to hypothetical debate. It works, and it works very well.
    edited 2014-11-10 02:41
    Yes, it seems to work well on the Propeller. The only point I've ever tried to make is that it isn't the only language that works well.
  • JDatJDat Posts: 103
    edited 2014-11-10 02:57
    Forth... I tried Forth on PC, on Nokia Symbian (J2ME), on Arduino. So? It is interesting, but useless for me. Why? Show me ARTnet to DMX node with enc28j60 module code in Forth. Or at least libraries that I can combine together. I read lot about Forthists. Tere are the same tendency: "I wrote forth for xxx system. It great easy and frexible. You must try it!". Come on. Show me results, not language. How many forth core are on OBEX? How many working projects are on Forts? The simple and real DIYers projects with PWM,servo,G-code,i2c,SPI,etc daily stuff, not theoretical Areospeace,FedEx,Science stuff.
    Regarding David problem, Tachyon even more useless if I can't redefine word and use it immediately. Why Tachyon just simply no read word from vocabulary end execute them? Nonsence!
    PS: Never advice me to use forth on propeller!
    edited 2014-11-10 03:40
    @JDat,
    Please read the Forum Rules:
    http://forums.parallax.com/showthread.php/134682-Forum-Guidelines
    Be polite:
    Polite lively debate is welcome. ‘Flaming,’ rude behavior, and personal insults are not productive and will not be tolerated. Swearing is absolutely not allowed. Members of the forum who engage in this behavior will be subject to a warning or permanent ban from the Parallax Discussion Forums.
    edited 2014-11-10 03:47
    JDat wrote: »
    I have no doubt that Peter could whip these up in a matter of hours or less using Tachyon.
    I guess you haven't been following Tachyon very closely. The whole reason that it is discussed so much in these forums is that Peter *has* done a lot more than just provide a nifty language. He has used it to provide a complete set of tools for working with the Propeller in an amazingly compact system.[/quote]
    In practice, I suspect this isn't needed all that often. I asked about it not because I thought it was a "must have" feature but because I thought Tachyon already had it and I wanted to understand it a little better for possible inclusion in a language I've been playing with. In fact, I'm finally realizing that I need to stop inventing languages and start using them. Your criticism doesn't apply at all to Tachyon but it does apply to the "little languages" I've been working on. I have never fleshed them out enough to be really useful. Peter has.
    edited 2014-11-10 04:34
    Hmmm....as usual these little language chats turn into a pub brawl. Let's not do that.
    This thread opened with a simple question and we have the simple answer. And the reasoning behind it.
    Tachyon may well not redefine words in the way we expect but it is designed that way and for good reason it seems. It turns out that other Forth like systems behave the same way, for example gforth. (I say "Forth like" because it seems they are all different, Forthers take pride in doing there own thing and I can't pin down the "Real Forth").
    Certainly you can't redefine function and variable names at run time in most other languages at all. For example C, Pascal...
    If you want weird try JavaScript. This code:
    function x() { console.log("Original x here"); };
    x();
    function x() { console.log("Redefined x here"); };
    x();
    Prints out:
    Redefined x here
    Redefined x here
    WTF you might think initially!
    edited 2014-11-10 04:39
    Heater. wrote: »
    x();
    x();
    Prints out:
    Redefined x here
    Redefined x here
    I assume you're not typing this interactively one line at a time?
