Making your own encoders? — Parallax Forums
AGCBAGCB Posts: 344
edited 2014-11-09 12:57 in General Discussion
In the various messages I've read about using encoders, I'm unsure as to what kind of encoders people are using.
Are they Bourns or some other brand or are they home printed code wheels and some type of interrupter or reflective unit.
I've used all 3 but would like to know what most people most often use. This would be for a motor shaft or wheel mostly.
Aaron
    edited 2014-11-06 13:42
    For cost reasons, I think most people use printed code wheels, or in the case of the new BOE-Bot wheels, slots molded into the wheels themselves.
    Home printing doesn't always work, especially when using dye-based inkjet inks. The ink doesn't absorb infrared light very well. Works better if you use laser printer toner, or better yet cut vinyl.
    For very high resolution an external self-contained encoder is really the only way to go. For the brave with good shop experience, the optics and codewheels for these are available at a reasonable price from US. Digital.
    edited 2014-11-06 13:55
    Further, there are motor encoders and wheel encoders. The S2 uses motor encoders. Many homebuilt bots use wheel encoders. Both function similarly to count rotations, but clearly a motor encoder must function at higher RPM than a wheel encoder . Quadrature encoders use 2 optical sensors per disk, and can tell the direction of rotation in addition to measuring rotation. A one-sensor "encoder" is technically called a tach sensor. Gives rotation distance only, not direction.
    http://en.wikipedia.org/wiki/Rotary_encoder
  • DomanikDomanik Posts: 233
    edited 2014-11-06 14:24
    ... the optics and codewheels for these are available at a reasonable price from US. Digital.
    Thanks for the info Gordon, looked at their site: http://www.usdigital.com/products/encoders/incremental/rotary/disks/DISK-2
    I'm planning on making my own encoders with hall-effect sensors. Just received 2mm diam x 1mm thick magnets and a motor with gear reduction. Plan to drill holes in the gear, insert magnets, position hall-effect on proto-board, then read the latched output. I know, I know, lotta work, huh? But fun.
    Dom..
    edited 2014-11-06 15:44
    Here's one way to make a very inexpensive magnetic encoder:
    edited 2014-11-06 18:02
    That was very clever, PhiPi, one of my faves!
    edited 2014-11-06 20:17
    Domanik wrote: »
    If the gears are iron based (you can check) you need only a Hall effect sensor and a magnet *behind* the sensor. This creates a flux that the sensor will read as the gear teeth roll by. Saves you from drilling out a gear and gluing on magnets. Worth checking if the gear is ferrite-based.
    If the motor doesn't have enough reduction, you can add an additional stage using inexpensive metal and high strength plastic (and composite) gears. Traxxas and other makers of R/C parts have several to choose from, in standard pitches. To reduce weight the gears often have the holes already in them. You could use those for a nice optical encoder system.
    edited 2014-11-07 14:17
    OMG! That is so simple. A FIXED magnet causing a change in flux as the moving gear teeth cut through the magnetic field. I will definitely try that. I have several hall sensors: 45g, 95g, 150g, 260g, both latched and unlatched, to experiment with. They're the 3 pin TO-92 really flat 2mm thick package. My guess is the hall sensor would need to be pretty sensitive to pick up the gear teeth. It might be limited in position in order to work reliably. Since the sensors have a logic 1/0 the sensitivity is already fixed and I'd need to change position to determine the safe operating range.
    Previously I did try to magnetize the gear but the field was weak and I was concerned the magnetism would diminish with time. So I bought 50 neodymium magnets for $4 instead. Drilled the gear with a 5/64" and the hole size came out to 2.00mm. Very nice. Note to self: use lots of high pressure air to blow away all filings before test fitting the magnets.
    A while back I thought about using the teeth as part of an optical encoder but thought the grease might plug it up. However using your idea above with the fixed magnet, holes in the gear might make the change in flux more dramatic, ie more easily detected. Much fun ahead experimenting.
    Dom..
    edited 2014-11-07 14:35
    Phil, I like the wooden wheels. Can't get much cheaper than that except for jar lids. Nice info about the magnetic fields spreading out at 0.163" along the magnet.
    ran across this from Pololu: http://www.pololu.com/product/2598 using some kinda magnet on the motor shaft.
    Dom..
  • AGCBAGCB Posts: 344
    edited 2014-11-07 16:35
    Thanks for all the replies. Things I hadn't seen before or thought of. Had to go try the fridge magnets and show my wife. Things will be lying on the floor by the refrigerator from now on, hehe.
    Those encoders online are out of my comfortable price range except for maybe a special project.
    Thanks again
    Aaron
    edited 2014-11-07 18:55
    Ebay is chock full of these sturdy ball bearing quadrature encoder modules for 12-15 dollars. Might work for odometry on a trailing wheel on a robot.
    http://www.ebay.com/itm/171122637698
    edited 2014-11-07 19:14
    When I read your post my eyes glazed over and when I woke up
    paypal was telling me I just bought 20. . . So what am I supposed to do with 50 lasers, 20 solar panels, 25 IR detectors and, now, 20 rotary encoders. I believe erco spelled backwards is hoarder...:D Actually thanks for the hot ebay tips.
    Dom..
    edited 2014-11-07 19:31
    Dom: You're new here. Welcome. You probably aren't aware of the fun forum fact that every time you buy something I recommed on Ebay, you owe me a dollar for my twins' college fund. It's honor system, so just do the right thing.
    Yes, JK... :)
  • WhitWhit Posts: 4,191
    edited 2014-11-07 19:38
    Domanik wrote: »
    Dom..
    @Dom - Welcome the Forums and being erco's latest victim. We've all ordered stuff that he put us on too!
    edited 2014-11-07 19:57
    Yes, JK... :)
    I just sent $115 to your paypal account. That was that $1 per item wasn't it or, hmm let me re-read that? DARN!!!
    edited 2014-11-08 11:06
    Wrapping up this homemade encoder project, I found:
    1) It works
    2) the hall-effect sensor must be perpendicular to the N-S field for maximum sensitivity
    3) a 45 Gauss HE works fine. Using the 2mm neodymium magnets up to a distance of about 5mm works, but too close cause other problems
    4) The 2 magnets must have poles opposite each other to flip the latched HE
    5) A non-latched HE produces pulses, not a symmetrical waveform
    6) Drilling the holes precisely opposite each other is important. Any offset will produce a corresponding non-symmetry in the encoder duty cycle
    7) Putting the HE very close to the magnets causes random pulses within the duty cycle. Random pulses were also produced when touching the rough surface of the gear face
    8) I couldn't find a spot on the gear perimeter close to the teeth that would produce a pulse even though the gear is ferromagnetic. Ferromagnetic gears will tend to hold on to the majority of the magnetic field. What's left over makes it to the HE.
    9) The pickup is more sensitive on the top of the gear than the bottom due to the countersink shoulder absorbing more of the magnetic field
    10) Probably, if the top of the magnet is flush or higher than the gear face, it will have more range
    11) A non-ferromagnetic (like brass or plastic) gear will allow more of the magnetic field to escape and reach out further to the HE.
    Photo 1. Drilled through with a 1/16" then countersunk with a 5/64". This gave me a perfect 2.00mm. Once the magnets were in two points near the top edge were peened to hold the magnet in-- no glue required. BTW I should have tested BOTH magnets with the HE for polarity Before inserting them. When it didn't work the first time with the HE, I had to pound out one magnet to flip it the other way.
    Photo 2. I scribed the drill lines with an exacto knife and steel rule. Then marked the other points and measured the distance of each along the diameter to be sure they are equal, then used the tip of a jewelers file to create an indent. Be sure to 100% clean all filings off the gear and every nook and cranny-- these magnets will find every one you miss -- lots of compressed air works best. When taking the magnets out of the package I scratched the surface of both before inserting. Still got it wrong the first time.
    Photo 3. This is the back of the gear showing the magnet up against the countersink shoulder. The drill press had chatter but once it started a hole the tip of the bit settle down to make a pretty accurate hole. The gear metal was surprisingly soft, like a cold rolled steel. That made it easier.
    Photo 4. This was my test setup that allowed me to measure various HEs, at a variety of distances and orientations. I plan to file a slot in the bottom of the plastic housing and use a small protoPCB to mount the HE. The HE will slip through the slot, under the gear. The magnetics are not as strong on the back side. Plan B might be to use that brass gear instead to get a higher pulse rate. Currently the output shaft is 7rpm, the HE cycle time is 160ms, so the brass gear would have been a better choice.
    If direction indication is needed I believe 2 HEs next to each other could feed a D latch. The output should tell you the direction.
    I think this gives me enough hands on experience to select from a large variety of motors and put an encoder in it. The cost is minimal and gives me a much wider selection of form factors, built in gear reductions, torques, and operating voltages. An off the shelf motor with encoder runs about 5X to 10X more, however the quality is much higher than the typical motors I get off ebay from China.
    Dom..
    1024 x 768 - 78K
    1024 x 768 - 80K
    500 x 286 - 10K
    1024 x 907 - 76K
    edited 2014-11-08 11:48
    Impressive work and feedback, Dom! You will fit right in here.
    edited 2014-11-08 11:53
    I have a few encoder related links listed under "Encoders" in post #5 of my index.
    I keep hoping to replace the pots inside servos with some sort of encoder. I've got this to work reasonably well with some optical encoders but my attempt to place a 12-bit magnetic encoder inside a servo, it didn't work very well.
    Erco got me hooked on Hamamatsu P5587 sensors but they're discontinued. I'd like to find a good replacement. I'm thinking something like the QRE1113 might work. I'd like to be able to make a PBC as small as the one shown in the photo below with a currently available sensor.
    Parallax sells some nice motors with encoders.
    I have four of these I plan to use with Mecanum wheels.
    28819.png?itok=Qe7nXLS4
    Pololu sells a bunch of different motors with encoders. I've used their 70:1 sets and I think they work great.
    0J4045.200.jpg?28764d04f44f69e259218bf608e862b4
    I usually buy this sort of stuff from Pololu on their Black Friday sale.
    Many of the versions of Dagu's Rover 5 include encoders. I have a couple of Rover 5 based robots and IMO, the encoders on the Rover 5's I have work great.
    edited 2014-11-09 09:04
    Duane Degn wrote: »
    Yes, those are nice motors and with Parallax you can't go wrong. I like the Pololu encoder attachment on the end of the shaft and they sell the magnets separately. A few weeks ago I started out hoping to make or buy some kind of optical encoder (read many of erco's and your posts). The idea of putting a magnet in the gear really appealed to me because it was simple and moved the sensor to the inside of the motor out of the external (unpredictable) environment. I'm musing about another possible project. Seems like it would be nice to have a single board with PWM, H-bridge, sensor feedback circuit, 3V regulator and 4 wire connections: Pwr, Gnd, SCL and SDA such that a controller could set it and forget it. Readback to the controller might be current and fault for example.
    Dom..
    Yea, but they're getting expensive. If I'm going to upgrade all the servos in a hexapod to use encoders rather than pots, then I need to find a reasonably priced sensor.
