UNI/O driver? — Parallax Forums
UNI/O driver?
RaymanRayman Posts: 15,939
edited 2014-11-06 14:50 in Propeller 1
Anybody have or seen a UNI/O driver for Propeller?
This seems to be a new 1-wire like protocol that Microchip now has for EEPROMs.
I'm trying to hack my Da Vinci 3D printer's filament cartridge... Turns out all I have to do is reprogram that EEPROM.
Then, I can load it up with Makerbot filament (that I have a lot of...).
I could convert Arduino code, if a driver doesn't already exist...
The Microchip device in Da Vinci is the 11LC010
  • JonnyMacJonnyMac Posts: 9,571
    edited 2014-11-06 09:39
    I hadn't heard of that driver until now -- will order a breadboard-friendly TO-92 EE from Digikey to give it a try. Shouldn't be very difficult to write a PASM driver for that buss (I know you'll beat me to it, so let's compare notes later).
  • RaymanRayman Posts: 15,939
    edited 2014-11-06 10:16
    I'm actually pretty busy and this isn't urgent, so I'm more than happy to wait :)
    Don't think assembly speed is required since only writing a few bytes and just one time...
    edited 2014-11-06 11:24
    TO-92 is interesting! Don't think I've ever seen eeprom like that before...
    Actually, I suppose these tiny things do save a lot of board space and one I/O pin...
    Doesn't need pullup resistors either.
    A long time ago one used to be able to get Dallas 1-Wire EEPROMs, but these look easier to use. I'll try it in Spin, first, and then give a PASM driver a try.
  • Hello All,
    Dragging this post up from the past.....did any of you write up a driver for the UNI/O?
  • unio is pretty simple to implement.. to bad largest unio eeprom is only 2K byte
  • *bump* wondering whether anyone got uni/o working? @rayman @jonnymac ?
    If not I'll have a go at something basic today with P2
  • I have not. Distractions. Distractions. Distractions.
