Kye's HidEngine - can't use a keyboard — Parallax Forums
pik33pik33 Posts: 2,415
edited 2014-11-06 09:07 in Propeller 1
On my p1v retromachine I used this driver to attach a mouse. It run as expected.
The keyboard is not detected. Instead it blinks all three its LEDs. I tried 2 different keyboards.
Simpler driver, http://obex.parallax.com/object/181 works OK - what can be wrong?
  • KyeKye Posts: 2,200
    edited 2014-11-05 06:23
    Yeah, my keyboard driver doesn't work with all keyboards... I could never figure out why. Just use the Parallax one.
    It does work with some keyboards however... I didn't just release something completely broken - I wrote that code back as a freshman in college...
    edited 2014-11-05 12:23
    Kye,
    Some keyboards clock at way different frequencies - I found this out in my 1pin keyboard driver. Did you do a form of autobauding?
    Yeah,
    I think it has something to do with that. The driver runs a mouse and keyboard at the same time so I have to sample the data versus using waitpne to align perfectly with it. Assuming the data comes faster than about 20 KHz things won't work...
