GPS active antenna spec
I came across this http://parallax.com/product/28502 antenna that I plan to use with my GPS unit.
So far the only requirement for the antenna is that it has to be "active".
Now, the word "active" means that it requires an external power supply circuitry. But how many volts and at what current?
Does it have a built in biasing circuit and the rf coupling capacitor or should I provide it externally?
Since a specification for this particular antenna is non existent I am asking for some help from whoever uses this particular antenna (or similar) to spare any info on how to properly interface it to a GPS module.
Typically they are powered by DC that is run through the feedline, so no extra wiring is needed to the antenna. The GPS module I used it with (Adafruit's Ultimate GPS breakout) needed nothing else, the power was derived internally in the GPS module, and the receiver would auto-detect the antenna. There's even a proprietary NMEA sentence that gives you external antenna status. As to why you need an "active" external antenna, I think it's mostly to compensate for feedline losses, which are high at >1 GHz.
To use you just connect it to your OEM GPS module, and it will automatically be used. One thing to be careful of is that it has a MMX connector, which is pretty rare. Most GPS units use SMA connector or a u.FL connector.
What GPS are you using?
Can somebody who uses this antenna post a picture of the other side where I believe might be at least some sticker with "additional" info?
Sparkfun has an adapter for $8.95. Beats soldering.
https://www.sparkfun.com/products/285
Is the LNA inside this particular antenna 5V tolerant is yet another question ...
Thanks, that's exactly what I was hoping for and very reassuring .
