useing bs2 with flexinol muscle wire?
is it possible to use the bs2 with muscle wire in a project?
is it documented ?
if not can we design·or post here a single working muscle circuit?
Post Edited (iamdenteddisk) : 6/17/2008 12:05:49 AM GMT
is it documented ?
Not that I know of.
I suppose the members of the board could help you figure it out, but you'd need to tell us what you're trying to do, the level of contraction you need and the width (the diameter) which will determine the amperage you need. It's not a one time thing as the diameter and length of the wire change the voltage and amperage needed. For most applications a tradition actuator, motor, servo, etc. would be better. What specifically are you trying to do?
- Stephen
this is a topic started by me as a pre-research chance to fish for leads info/schematic's leads about·useing the bs2 to control flexinol muscle wire as actuator's for robot projects.
so far we have heard a few characteristics /unverified..
slow in action
3v for 12cm
2second contractions
the statement·about current is ignored on the grounds that the "flexinol will work" though be-it indirectly meaning "support circuits ,external power or relay's,switch's may be needed·needed",this is normal when connecting devices and should in no way rule out the bs2 as a viable controler.
still not enough to make out·a clear picture. but these will be verified or flushed thanks guy's keep em comeing..
Post Edited (iamdenteddisk) : 6/18/2008 2:05:30 AM GMT
Nitinol is the classic solution in search of the right problem.
Post Edited (erco) : 6/19/2008 3:42:53 PM GMT
ahha..now where getting somewhere useing pwm on an analog device this is getting intresting thanks mike ,though it is analogous to throwing water on a greese fire it actualy makes perfect sense ,to me any way ..but useing pwm is a current limiting Resistor still required?
IM·imagineing the liner fall like that of a discharging capacitor as current switches on the Voltage will rise to peek then fall starting at the end of a pulse wich then is met with the following on pulse like a triangle waveform across the flexinol
but as the tepurature rises the resistance of the wire falls ...um I think im getting confused here..
.can anyone give schematic with 12cm at 3v im lost at the value of (R)?
Post Edited (iamdenteddisk) : 6/25/2008 6:17:52 AM GMT
Hi erco,
I'm digging around still trying to make my flower petals move, and wanted to use Flexinol as well as the petals will be slow moving and the petals are only 2cm small each. I'm using the Homework Board and know it needs more power, but I'm not sure how to add more power and still use the board. I know MOSFET is a key, but I'm not sure how to tie it all together on the board. BRAIN DISCONNECT. See pic. (I was going to also replace the 9v battery with a 9v AC adapter as well cause I wanted it to run for months). HELPPPPPPP
C.
I was impressed with this material (also called shape memory alloy, I think) at the time until I started to understand the current needs and mechanical design needed to make a little movement have visible results.
It's interesting to play with and probably lends itself well to organic types of robotic projects, but it's also a bit of a project to create the mechanics you want to move around.
Please read the forum guidlines:
http://forums.parallax.com/showthread.php/134682-Forum-Guidelines
