serial-communicatins with simple-ide
hi
in the moment i working with a
propeller professional development-board (PPDB)
my first experiments with serial-com.
base: serialcom from the ppdb with rs232-converter-cable to usb to my linux box
with spin is the communication ok
yesterday controlling 2 servos with simpleide OK
now with c:
after much improvements compile is ok
but the test with linux is not ok
no communications ppdb should send: "$1:2:3:4:"
now what make i wrong, is the code correct:
sending a string to linux
please can somebody help me.
thanks for your help , hints and tricks...
regards
nomad
/code:
Blank Simple Project.c
http://learn.parallax.com/propeller-c-tutorials
dd. 02.11.2014
- base : the same HW Config as Spin
- pin 27 = tx yellow transmit
pin 28 = rx green receive
- baud: 9600
- RS232-Converter-USB-Kabel on V3 with /dev/ttyUSB0
- no realy demos here (lcd and xbee)
- compile failures....
- with only fdserial.h included compile ok
ref:
notes:
einbau von simpletext.h
serial.h
fdserial.h
//#include "simpletools.h" // Include simple tools
//#include "simpletext.h"
//#include "serial.h"
#include "fdserial.h"
// rx = pin 28
// tx = pin 27
fdserial *term; // should terminal
int main() // Main function
// Add startup code here.
term = fdserial_open(28, 27, 0, 9600);
while(1)
// Add main loop code here.
writeStr(term,"$:1:2:3:4:");
//writeChar(term, CR );
dprint(term,"$1:2:3:4:");
hi
now with c:
regards
nomad
/code:
dd. 02.11.2014
- baud: 9600
ref:
notes:
serial.h
fdserial.h
// rx = pin 28
// tx = pin 27
while(1)
At the beginning of int main(), add the following code. I don't know if that will fix it, but it is something worth trying.
Also, you need to change the baud rate to 115200.
Best of luck,
ValeT
today i testing this and make eventualy a reply
regards nomad
your hints are OK
its running , i work with fdserial.h then fdserial_close(term) is ok, baudrate 115200 ok
thanks for your fast help
regards
nomad
Glad I can help
