Having trouble with "ftell()"
Hi there!
I'm hoping that someone can point me in the right direction.
I'm not getting expected return from ftell()...it always returns zero on my system.
I've put together the following simplistic example:
Am I doing this wrong?
Thanks in advance,
Ron
#include "simpletools.h"
#define SDDO 22
#define SDCLK 23
#define SDDI 24
#define SDCS 25
int main()
char textForFile[] = "Testing 123...Add extra data...\n";
char s[15], t[15];
unsigned long position;
sd_mount(SDDO,SDCLK,SDDI,SDCS);
print("Open file for writing\n");
FILE* fp = fopen("new1.raw", "wb");
if(fp==NULL){print("ERROR opening file fro Write\n");}
print("Write to file\n");
fwrite(textForFile,1,sizeof(textForFile),fp);
print("Closing file\n");
fclose(fp);
fp = NULL;
print("Opening file for Read\n");
fp = fopen("new1.raw","rb");
if(fp==NULL){print("ERROR opening file for Read\n");}
position = ftell(fp);
printf("Current position is %lu \n",position);
fread(s, 1, 15, fp);
printf("Reading file data: %s \n",s);
fseek(fp, 0, SEEK_END);
print("Seeking to end\n");
printf("Now current position is %lu \n",position); //On my system I get zero here?
fread(t, 1, 15, fp);
printf("Reading file data: %s \n",t); //shouldn't get good data here...I'm past END
print("Rewinding\n");
rewind(fp);
printf("Read file data after rewind: %s \n",t); //Now I get good data, which is correct.
while(1)
Thanks in advance,
Ron
I seem to have replicated the problem here. I changed the code up to check for errors along the way. here's the results:
Which is a result of this code:
#include <simpletools.h> #define MISO 1 #define SCLK 2 #define MOSI 0 #define CS 4 int createTestFile (); const char textForFile[] = "Testing 123...Add extra data...\n"; int main () { char s[15], t[15]; int position; int err; FILE *fp; if ((err = sd_mount(MISO, SCLK, MOSI, CS))) { print("Error mounting SD card: %d. Now exiting.\n", err); return 1; } // Create a test file. Exit if it failed if (createTestFile()) return 1; // Open file for read print("Opening file for Read\n"); fp = fopen("new1.raw", "rb"); if (fp == NULL) { print("ERROR opening file for Read\n"); return 1; } // Read some bytes from the file position = ftell(fp); print("\nPosition at start: %d\n", position); fread(s, 1, 15, fp); print("Read data from file: \"%s\"\n", s); // Seek to end print("\nSeeking to end\n"); if ((err = fseek(fp, 0, SEEK_END))) { print("Error during seek: %d\n", err); return 1; } position = ftell(fp); print("Now current position is %d\n", position); //shouldn't get good data here...I'm past END if ((err = fread(t, 1, 15, fp))) { print("\nWas not expecting to read anything. Instead, read %d bytes\n", err); print("Read data from file: \"%s\"\n", t); } else print("\nNo data expected and no data read. That's good.\n"); print("\nRewinding\n"); rewind(fp); fread(t, 1, 15, fp); //Now I get good data, which is correct. print("Read file data after rewind: \"%s\"\n", t); return 0; } int createTestFile () {// Attempt to open file print("Open file for writing\n"); FILE *fp = fopen("new1.raw", "wb"); if (fp == NULL) { print("ERROR opening file fro Write\n"); return 1; } // Write some stuff to the file print("Write to file\n"); fwrite(textForFile, 1, sizeof(textForFile), fp); // Close the file print("Closing file\n"); fclose(fp); return 0; }Sorry... you've written your code correctly, but this is a bug/not-yet-written-piece in PropGCC.
// function called by fseek static int File_fseek(FILE *fp, long int offset, int origin) { // This code needs to be enabled and tested PFILEINFO dfs_fp = (PFILEINFO)fp->drvarg[0]; if (origin == SEEK_CUR) offset += dfs_fp->pointer; else if (origin == SEEK_END) offset += dfs_fp->filelen; else if (origin != SEEK_SET) { errno = EIO; return -1; } if (offset < 0) offset = 0; DFS_Seek(dfs_fp, offset, dfs_scratch); return 0; }Thanks very much for your time/help!
If I understand you correctly, I should file this as a bug against propgcc on the code.google.com project site?
Yep, that would be good. If/when a fix gets committed, let me know and I'll rebuild the versions of PropGCC on my site.
David, I plan on checking it into the default branch. Are there any other branches that I should add it to?
Thanks for fixing this! Yes, you should probably also add it to the release_1_0 branch because that is what is currently used in the SimpleIDE releases.
David
