Can the propeller be used as a CAN sniffer? (bit collection project idea) - Page 2 — Parallax Forums
2»
  • turbosupraturbosupra Posts: 1,088
    edited 2014-10-29 17:42
    I don't know where that line came from, but thanks for correcting me. Why did you add a 0 byte at the end, to shift the remainder into?
    I have my .net program mostly done, but it is outputting more polys than your code does, so something is wrong with it. In an attempt to debug and correct my program, I chose a random poly for my program (100000100) with the same hex string of 53D2C800E9. My program outputs 0101001111010010110010000000000011101001 (53D2C800E9) with the poly 100000100 equals 000000000. I believe it does this incorrectly, because when I do it by hand I also get 000000000, so it is wrong because of something flawed with the way I'm doing it? I've tried to follow your method and the wiki example and both ways I do not get the correct answer per the online calculator. Then I tried to reread about the CRC method to see if I could figure out on my own what I'm doing wrong, but to no success.
    I have tried this at least 12 times today, to make sure I wasn't making the mistake of adding an extra line in again and I'm really not sure what is wrong.
    $ cc (hexadecimal)
    % 11001100 (binary)
    ! 204 (decimal)
    https://ghsi.de/CRC/index.php?Polynom=100000100&Message=53D2C800E9
                    000000000_0101001111010010110010000000000011101001
                    000000000_101001111010010110010000000000011101001
                    000000001_01001111010010110010000000000011101001
                    000000010_1001111010010110010000000000011101001
                    000000101_001111010010110010000000000011101001
                    000001010_01111010010110010000000000011101001
                    000010100_1111010010110010000000000011101001
                    000101001_111010010110010000000000011101001
                    001010011_11010010110010000000000011101001
                    010100111_1010010110010000000000011101001
                    101001111_010010110010000000000011101001
                    100000100
                    001001011_010010110010000000000011101001
                    100101101_0010110010000000000011101001
                    100000100
                    000101001_0010110010000000000011101001
                    101001001_0110010000000000011101001
                    100000100
                    001001101_0110010000000000011101001
                    100110101_10010000000000011101001
                    100000100
                    000110001_10010000000000011101001
                    110001100_10000000000011101001
                    100000100
                    010001000_10000000000011101001
                    100010001_0000000000011101001
                    100000100
                    000010101_0000000000011101001
                    101010000_000000011101001
                    100000100
                    001010100_000000011101001
                    101010000_0000011101001
                    100000100
                    001010100_0000011101001
                    101010000_00011101001
                    100000100
                    001010100_00011101001
                    101010000_011101001
                    100000100
                    001010100_011101001
                    101010001_1101001
                    100000100
                    001010101_1101001
                    101010111_01001
                    100000100
                    001010011_01001
                    101001101_001
                    100000100
                    001001001_001
                    100100100_1
                    100000100
                    000100000_1
                    100000100
                    100000100
                    000000000
  • ChrisGaddChrisGadd Posts: 311
    edited 2014-10-29 19:16
    Which 0 byte did I add where?
    One of the rules with crc polynomials is that they always begin and end with a set bit, as mentioned in the wikipedia article. The online calculator seems to assume that the lsb is set, as it produces the same result with %100000101 as it does with %100000100.
    As for why you were getting 000000000 when doing it by hand, you're shifting too many places - stop after all of the bits have been shifted.
                    001010011_01001  ' 5 bits remain to be shifted
                    101001101_001    ' 3
                    100000100
                    001001001_001    ' 3
                    100100100_1      ' 1
                    100000100
                    000100000_1      ' 1
                    100000100        ' shifted too far - should've stopped at 001000001 = $41
                    100000100
                    000000000
    A minor modification to my crc calculator routine - which doesn't assume anything about the polynomial - leaves $41 in the crc_result.
    edited 2014-10-29 20:02
    A few posts up with 05, to add the 0 byte.
    So the online calculator treats 100000100 as 100000101, as it sets the lsb to 1 in the code?
    Seeing that the calculator says that using a poly of 100000100 or 100000101 = 11001100 ($cc), is it wrong?
    I modified your code (I think correctly) and using a poly of 100000101, the remainder is 00111100 ($3c). Using a poly of 100000100, the remainder is 001000001 ($41). How did you know to stop at 001000001, because there were only 7 bits left when you do not, after removing the leading zeros?
    I will reread the wiki page again to try and make sure I know all of the CRC polynomial rules.
    edited 2014-10-30 06:28
    Neither calculator is wrong, they just use slightly different rules. The online crc calculator automatically pads every string with enough bits to complete the calculation. My object requires the padded bits to be entered into the string.
    With my object, $53D2C800E9_00 does come out to $CC with the polynomial $105, which is how the online one sees $104.
    online:       myobject:    (using $113 as the poly)
    $5   = $5F    $500 = $5F
    $55F = $00    $55F = $00
    The reason why both work for verifying $55F = $00 is that a string which is valid after n bits is still going to be valid after n + x clear bits.
    $55F000000000000000... also equals 0.
    What the online thing is really converting is:
    $500 = $5F
    $55F00 = $00
    I knew to stop because there was only a single bit remaining to be shifted. Stop after all of the bits have been shifted, that's it. If the bits are a,b,c,d, shift them into the working register (crc_result) until d is in the lsb, not until a is in the msb.
    000000000_abcd gets shifted to 00000abcd.
    If it helps, count the number of bits in the bitstream: $55F has 12 bits.
                |5-||--5F--|   shift_counter
      000000000_010101011111   start
      000000000_10101011111     1
      000000001_0101011111      2
      000000010_101011111       3
      000000101_01011111        4
      000001010_1011111         5
      000010101_011111          6
      000101010_11111           7
      001010101_1111            8
      010101011_111             9
      101010111_11             10
      100010011
      001000100_11
      010001001_1              11
      100010011_               12 - all bits have been shifted, still need to check bit8 and xor if set
      100010011
      000000000_               Finished!
    edited 2014-10-30 13:20
    Ok,
    I'm still a little fuzzy on what the online calc is doing differently. Does the online calculator take hex converted to binary, count the length of the binary digits, divide it by 8 and then determine the number of zeros it needs to pad to the right of the original binary, to have no remainder for that division? I believe this is wrong based on what I have shown below.
    So 5 (0101) would be converted to 01010000 by the online program or 01011111?
    5 = 5f          or 0101 = 01011111
    f5 = 4e         or 01011111 = 01001110
    5ff = 4d        or 010111111111 = 01001101
    500 = 5f        or 010100000000 = 010111111111
    The good news is that I have the .net program matching outputs from your program in all of my tests ... and a much better understanding of what your code does :)
    I have a decode method working with an indexer as to how frequent a poly comes up within a list of hex phrases, but I have not thoroughly tested it well. Is it correct (as a rule) that a crc8 has to start the polynomial xoring at 100000000 ?
    53_D2_C8_00_E9
    63_D2_2C_00_B5
    64_98_CC_02_A7_D4
    53_62_BF_00_78
    65_62_D2_00_A0_08_0A
    64_98_CC_02_A8_35
    53_EF_6A_04_44
    64_98_CC_02_A8_35
    64_FE_40_00_00_3E
    64_D2_26_00_00_B1
    53_D2_C8_00_E9
    63_D2_2C_00_B5
    64_98_CC_02_A7_D4
    53_D2_C8_00_E4
    53_D2_C8_00_E9
    100010011 (polynomial used)
    0 (remainder binary)
    0 (remainder hex)
    0 (remainder decimal)
    110111001 (polynomial used)
    0 (remainder hex)
    63_D2_2C_00_B5
    0 (remainder hex)
    64_98_CC_02_A7_D4
    00 (remainder binary)
    0 (remainder hex)
    111100010 (polynomial used)
    0 (remainder hex)
    53_62_BF_00_78
    None found
    100100111 (polynomial used)
    0 (remainder hex)
    100101001 (polynomial used)
    0 (remainder hex)
    100101010 (polynomial used)
    0 (remainder hex)
    101000110 (polynomial used)
    0 (remainder hex)
    101001010 (polynomial used)
    0 (remainder hex)
    101011001 (polynomial used)
    0 (remainder hex)
    110111111 (polynomial used)
    0 (remainder hex)
    111001110 (polynomial used)
    0 (remainder hex)
    111100101 (polynomial used)
    0 (remainder hex)
    111101111 (polynomial used)
    0 (remainder hex)
    64_98_CC_02_A8_35
    0 (remainder hex)
    53_EF_6A_04_44
    101001110 (polynomial used)
    0 (remainder hex)
    111101001 (polynomial used)
    0 (remainder hex)
    64_98_CC_02_A8_35
    0 (remainder hex)
    64_FE_40_00_00_3E
    0 (remainder hex)
    100010101 (polynomial used)
    0 (remainder hex)
    0 (remainder hex)
    111100110 (polynomial used)
    0 (remainder hex)
    64_D2_26_00_00_B1
    0 (remainder hex)
    110101001 (polynomial used)
    0 (remainder hex)
    53_D2_C8_00_E9
    0 (remainder hex)
    0 (remainder hex)
    63_D2_2C_00_B5
    0 (remainder hex)
    64_98_CC_02_A7_D4
    0 (remainder hex)
    0 (remainder hex)
    53_D2_C8_00_E4
    110001101 (polynomial used)
    0 (remainder hex)
    3 | 111100010 (frequency count)
    2 | 110111001 (frequency count)
    10 | 100010011 (frequency count)
    1 | 111101111 (frequency count)
    1 | 111101001 (frequency count)
    1 | 111100110 (frequency count)
    1 | 111100101 (frequency count)
    1 | 111001110 (frequency count)
    1 | 110111111 (frequency count)
    1 | 110101001 (frequency count)
    1 | 110001101 (frequency count)
    1 | 101011001 (frequency count)
    1 | 101001110 (frequency count)
    1 | 101001010 (frequency count)
    1 | 101000110 (frequency count)
    1 | 100101010 (frequency count)
    1 | 100101001 (frequency count)
    1 | 100100111 (frequency count)
    1 | 100010101 (frequency count)
    edited 2014-10-30 15:29
    turbosupra wrote: »
    Ok,
    Hex converted to binary divided by 8... I have no idea what you're asking there.
    By converted do you mean the result of the computation? The result of $5 with with the polynomial $113 is $5F. Perhaps you mean the value with the padded bits? Since the polynomial is 9 bits, the result will be 8 bits, so the padded value would be $500. Wikipedia also explains that under the computation section. You can also see this on the online calculator, notice how the number of bits in the binary result is one less than the number of bits in the polynomial?
    5 = 5f          or 0101 = 01011111                - correct
    f5 = 4e         or 01011111 = 01001110            -correct
    5ff = 4d        or 010111111111 = 01001101        -correct
    500 = 5f        or 010100000000 = 010111111111    -???
    Right, a crc-8 is 9 bits - and only odd, so start from $101 and check every other poly up to $1FF.
    Here's a new version of my calculator that behaves more like the online calculator; automatically pads the value depending on the length of the polynomial.
    CRC calculator 3.spin
    edited 2014-10-31 08:32
    Ok, so what I'm fuzzy on is with the different outputs. Does the online calculator always ensure the last polynomial bit is a 1? Is that what it is doing?
    What is the difference between the outputs of your 1st calculator and 3rd?
    5 with $113 / 100010011
    OnlineCalc = 5f / 01011111
    Crc calculator3 = 5f / 001011111
    My program = 5 / 101
    Cr calculator1 = 5 / 101
      000000101   5
      100010011
     [b] 100010110[/b]
      00000010100000000   5 padded
            100010011
            00101001100
              100010011
             [b] 001011111[/b]
    5f with $113 / 100010011
    OnlineCalc = 4e / 01001110
    My program = 5f / 1011111
    Cr calculator1 = 5f / 1011111
      001011111   5f
      100010011
      [b]101001100[/b]
      00101111100000000   5f padded
        100010011
        001101111000000
          100010011
          0101011110000
           100010011
           001001101000
             100010011
            [b] 0001001110[/b]
    5ff with $113 / 100010011
    OnlineCalc = 4d / 01001101
    My program = A0 / 10100000
    Cr calculator1 = A0 / 010100000
    By hand = 10100000
      010111111111  5ff
       100010011
       00110110011
         100010011
        [b] 010100000[/b]
      01011111111100000000   5ff padded
       100010011
       00110110011
         100010011
         01010000000000000
          100010011
          0010100110000000
            100010011
            00101111100000
              100010011
              001101111000
                100010011
                0101011110
                 100010011
                [b] 001001101[/b]
    5fff with $113 / 100010011
    OnlineCalc = 7d / 01111101
    My program = B1 / 10110001
    Cr calculator1 = B1 / 10110001
    By hand = 10110001
      0101111111111111   5fff
       100010011
       001101100111111
         100010011
         0101000001111
          100010011
          001010010111
            100010011
           [b] 0010110001[/b]
      010111111111111100000000   5fff padded
       100010011
       001101100111111
         100010011
         0101000001111
          100010011
          001010010111
            100010011
            001011000100000000
              100010011
              0011100010000000
                100010011
                01101011100000
                 100010011
                 0101111010000
                  100010011
                  001101001000
                    100010011
                    0101101110
                     100010011
                     [b]001111101[/b]
    5fff5 with $113 / 100010011
    OnlineCalc = f6 / 11110110
    Crc calculator3 = F0 / 011110000
    My program = B8 / 10111000
    Cr calculator1 = B8 / 10111000
    By hand = 010111000
      01011111111111110101   5fff5
       100010011
       0011011001111110101
         100010011
         01010000011110101
          100010011
          0010100101110101
            100010011
            00101100010101
              100010011
              001110001101
                100010011
                0110101011
                 100010011
                [b] 010111000[/b]
      0101111111111111010100000000   5fff5 padded
       100010011
       0011011001111110101
         100010011
         01010000011110101
          100010011
          0010100101110101
            100010011
            00101100010101
              100010011
              001110001101
                100010011
                0110101011
                 100010011
                 01011100000000000
                  100010011
                  0011000110000000
                    100010011
                    01001111100000
                     100010011
                     0001011010000
                        100010011
                        [b]0011110110[/b]
    DEADBEEF with $113 / 100010011
    OnlineCalc = D1 / 11010001
    Crc calculator3 = D1 / 011010001
    My program = 1E / 11110
    Cr calculator1 = 1E / 11110
    53_D2_C8_00_E9_00 with $105 / 100000101
    OnlineCalc = F3 / 11110011
    Crc calculator3 = F3 / 011110011
    My program = CC / 11001100
    Cr calculator1 = CC / 11001100
    edited 2014-10-31 09:14
    In case you wanted to try the exe file, definitely beta by the way
    edited 2014-10-31 09:25
    The difference between calculator 1 (& 2) and calculator 3 is that 1 & 2 require the padded bits to be entered into the string, calculator 3 automatically pads with the required number of bits.
    In the get_crc method, after it has looped through all of the bits of all of the nibbles from all of the characters in the string, the program enters a second loop:
      repeat >| poly - 1         ' repeat this loop for all bits in the polynomial - 1.  For a 9-bit crc (crc-8), this repeats 8 times.  Go ahead and replace this with [b]repeat 8[/b] if ya want.
        crc_result <<= 1         ' The rest of this is just like the code that appends bits from nib, except here all we need to do is pad with 0's, which is what happens during a left shift.
        if crc_result => $100    ' Check to see if bit 8 is set
          crc_result ^= poly     ' xor with the polynomial if it is
      return crc_result
    As for why calculator3 was giving different results than the online calculator, you're entering the hex digits in lower case. Modify the get_nibble method as:
      case [b]byte[/b][ptr]
        "0".."9" [b]: return byte[/b][ptr] - "0"
        "A".."F" [b]: return byte[/b][ptr] - "7"
        "a".."f" [b]: return byte[/b][ptr] - "W"
        other[b]: return[/b] -1
    It is, of course, entirely up to you how you want to handle the string formation regarding the padding. For my CANbus objects, I have separate routines for transmitting and receiving.
    For transmitting, I have each field of the message stored in its own register. For BEAN, you’ll likely have priority and message length in one byte, message ID, destination ID, and up to 11 data bytes. To transmit that, I’d load one byte at a time, and in the same loop that transmits the bits, append those same bits to the working register (crc_result). After the final data byte is sent, finish up the crc calculation by left shifting / checking / xor’ing eight times, and then the crc field will be ready to transmit.
    For receiving, parse every (non-stuffed) bit that comes in and also shift it into a working register. Parse the priority / message length, message ID, destination ID, and use the message length to initialize a loop counter for receiving data bytes. After the final data byte, parse the crc field. After the final bit of the crc field has been received, the working register should be empty – no padding required. $55F = 0, as does $55F00, as does $55F000000000000.
    Your routine should work fine for verifying strings, it’s simply creating the crc field where padding is needed.
    edited 2014-10-31 11:34
    Ok, that makes sense now that it is case insensitive.
    I'm still unsure as to why calculator 1/2 and calculator 3 have different values, I would have expected the end result to still be the same. With the padding and the answers being different, which technique is correct?
    With my program, I can append a zero byte ("_00") to the input hex values and get the same answer as CRC Calculator 3.spin. (I know you know this already) I can also add the 8 zeros manually in CRC Calculator 1/2.spin and also get the same value as Crc Calculator 3.spin.
    How can I know which way is correct?
    [u]5f[/u]
    Calculator 1/2/Me = 5f / 1011111
    Calculator 3 = 4e / 001001110
      001011111   5f
      100010011
      101001100
        100010011
        001101111000000
          100010011
          0101011110000
           100010011
           001001101000
             100010011
             0001001110
      000000000_00101111100000000   5f shifted left
      000000000_0101111100000000
      000000000_101111100000000
      000000001_01111100000000
      000000010_1111100000000
      000000101_111100000000
      000001011_11100000000
      000010111_1100000000
      000101111_100000000
      001011111_00000000
      010111110_0000000
      101111100_000000
      100010011
      001101111_000000
      110111100_0000
      100010011
      010101111_0000
      101011110_000
      100010011
      001001101_000
      100110100_0
      100010011
      000100111_0
    [u]5ff[/u]
    Calculator 1/2/Me =  A0 / 010100000
    Calculator 3 = 7d / 001001101
      010111111111   5ff
       100010011
       00110110011
         100010011
         010100000
       100010011
       00110110011
         100010011
         01010000000000000
          100010011
          0010100110000000
            100010011
            00101111100000
              100010011
              001101111000
                100010011
                0101011110
                 100010011
                 001001101
      000000000_010111111111   5ff shifted left (may be wrong)
      000000000_10111111111
      000000001_0111111111
      000000010_111111111
      000000101_11111111
      000001011_1111111
      000010111_111111
      000101111_11111
      001011111_1111
      010111111_111
      101111111_11
      100010011
      001101100_11
      110110011
      100010011
      010100000
    [u]5fff[/u]
    Calculator 1/2/Me = B1 / 10110001
    Calculator 3 = 7d / 001111101
       100010011
       001101100111111
         100010011
         0101000001111
          100010011
          001010010111
            100010011
            0010110001
       100010011
       001101100111111
         100010011
         0101000001111
          100010011
          001010010111
            100010011
            001011000100000000
              100010011
              0011100010000000
                100010011
                01101011100000
                 100010011
                 0101111010000
                  100010011
                  001101001000
                    100010011
                    0101101110
                     100010011
                     001111101
      000000000_0101111111111111   5fff shifted left
      000000000_101111111111111
      000000001_01111111111111
      000000010_1111111111111
      000000101_111111111111
      000001011_11111111111
      000010111_1111111111
      000101111_111111111
      001011111_11111111
      010111111_1111111
      101111111_111111
      100010011
      001101100_111111
      110110011_1111
      100010011
      010100000_1111
      101000001_111
      100010011
      001010010_111
      101001011_1
      100010011
      001011000_1
      010110001
    [u]5fff5[/u]
    Calculator 1/2/Me = B8 / 10111000
    Calculator 3 = F6 / 011110110
       100010011
       0011011001111110101
         100010011
         01010000011110101
          100010011
          0010100101110101
            100010011
            00101100010101
              100010011
              001110001101
                100010011
                0110101011
                 100010011
                 010111000
       100010011
       0011011001111110101
         100010011
         01010000011110101
          100010011
          0010100101110101
            100010011
            00101100010101
              100010011
              001110001101
                100010011
                0110101011
                 100010011
                 01011100000000000
                  100010011
                  0011000110000000
                    100010011
                    01001111100000
                     100010011
                     0001011010000
                        100010011
                        0011110110
      000000000_01011111111111110101   5fff5 shifted left
      000000000_1011111111111110101
      000000001_011111111111110101
      000000010_11111111111110101
      000000101_1111111111110101
      000001011_111111111110101
      000010111_11111111110101
      000101111_1111111110101
      001011111_111111110101
      010111111-11111110101
      101111111_1111110101
      100010011
      001101100_1111110101
      011011001_111110101
      110110011_11110101
      100010011
      010100000_11110101
      101000001_1110101
      100010011
      001010010_1110101
      010100101_110101
      101001011_10101
      100010011
      001011000_10101
      010110001_0101 \
      101100010_101
      100010011
      001110001_101
      111000110_1
      100010011
      011010101_1
      110101011
      100010011
      010111000
    edited 2014-10-31 15:01
    turbosupra wrote: »
    What you said is precisely why calculator 1/2 and calculator 3 have different values. Calculator 1 & 2 need the padded bits to be explicitly entered into the text string in order for the calculation to work. Calculator 3 automatically pads the text string with the required number of bits. Neither way is correct or incorrect, as long as you know which method you're using. As I mentioned just a couple posts back, for my CANbus transmitter I use a calculator3 type procedure, for the CANbus receiver I use a calculator 1/2 procedure. If the message is received correctly, the crc_result register will be zero after the final bit of the crc field has been parsed. Padding is required for determining what the crc field is when transmitting, padding is not necessary for verifying the received message.
