Solar powered Desktop PSU
Hello all once again! I found this and am wondering if this would be enough to power my computer in my shed :
http://www.mini-box.com/M4-ATX?sc=8&category=981
I really don't know what the minimum wattage needed would be, but the power supply in the computer is rated at 305W. That could be one more thing pulled off the grid
I doubt this computer pulls a solid 305W all the time so I should probably figure how many amps it draws while in use and when not in use. 250W = 20.8A which is quite a large load IMO.
If you have one hard drive and integrated graphics I think it would be more than enough.
After running the Kill A Watt meter on it for a bit, I found that running idle, it draws around 72 to 75 Watts and the highest I could get it to was 120W by opening a bunch of browser windows and streaming music. I also plan on converting my speakers to run from the battery bank and the wireless router (I use as a bridge) to run from it as well.
Your readings sound nominal and clearly don't even come close to the 250W. In reality, even a regular dedicated GPU gaming rig is topping out at 250W. Only the over the top rigs need more. That said, individual voltage rails can sag before reaching the full overall rating, so some overrating is wise.
The more stuff I can get off the grid, the more I can save in the long run so I need to maximize the amount of items that can feasibly run from the current setup I have. If I do it wisely, I am not dumping excess power to nothing like I am now. My batteries stay fully topped off all day and all night. I know as soon as I add a decent load, the batteries will drain quickly as I am just using 3 car batteries at the moment. I don't care about the batteries so if they Smile out, so be it.
The listed PSU has the ability to shut down the computer when the input voltage drops below a specified amount. This can be useful since I do run this computer 24/7 which is a waste of power.... If I use it only while I am in the shed, I could save about $3 to $4 a month. If I switch it to solar, I would save about $5 a month.
I really don't know the limit of my solar setup now since all I have running from it is a small computer fan that kicks on when the shed temperature is below the thermostat and the solar heater gets to 140 degrees, and the circuit that kicks on my shed lights with motion. A total draw of about 1A max. On one car battery, it was able to run for over 30 days without a charge.
Looking to the future - I hate lead-acids, the whole boost cycle thing is so messy and they're totally out performed these days - If you ever want to spend money on the batteries I suggest looking for the best float charged only setup. There is more of these tech batteries coming on to the market now but, sadly, the chargers are not keeping up. Forward looking companies that make the end equipment are forced to either remove the boost circuit, undocumented, from existing chargers or design their own charger.
EDIT: PS: The boost function is often in the firmware on new chargers so getting rid of it isn't as simple as removing a component from the PCB. Software lock-ins can stab you in the back in more than one way.
