Navigation with Whiskers with Arduino shield: Why are 220 ohm resistors needed?
Hi there,
I'm going through the tutorials for the BOE shield for Arduino kit, and I just added the whiskers. The robot is working great, but I can't figure out why the 220-ohm resistors shown below are needed in the whisker switch circuit. (Circuit diagrams from this page: http://learn.parallax.com/node/237 )
Isn't something like this all you need:
(Image from this Sparkfun tutorial: https://learn.sparkfun.com/tutorials/switch-basics )
Since I couldn't figure out any reason for the 220-ohm resistors to be there, I tried replacing them with wires like in the Sparkfun diagram, and everything still works the same. So why are those resistors there?
thanks!
Carol
thanks!
Carol
Carol
