<simpletools.h> long count ( int pin, long duration) doubles expected result?
When I use count(0,1000) to measure the 1000 baud square wave that my oscilloscope puts out, I get a return value which not only varies ~10%, but is double the value I expected. i.e. I get ~2000 when I expect ~1000.
Is this a bug? What is the maximum pulse rate I can measure this way?
Reference:
https://propsideworkspace.googlecode.com/hg-history/029efb9bf270758003c0a67571d1cbe4cc9986b5/Learn/Simple%20Libraries/Utility/libsimpletools/html/simpletools_8h.html#a20a9d97de9777b12cfd9353a83ac21cb
I have a really hard time interpreting the .asm rendition of the code:
The C code:
Reference:
GNU assembler version 2.21 (propeller-elf) using BFD version (propellergcc_v1_0_0_2408) 2.21. options passed : -lmm -ahdlnsg=lmm/PulseMonitor.asm input file : C:\Users\n\AppData\Local\Temp\ccIBm3CJ.s output file : lmm/PulseMonitor.o target : propeller-parallax-elf time stamp : 1 .text 2 .Ltext0 3 .data 4 .balign 4 5 .LC0 6 0000 25640A00 .ascii "%d\12\0" 7 .text 8 .balign 4 9 .global _main 10 _main 11 .LFB1 12 .file 1 "PulseMonitor.c" 1:PulseMonitor.c **** /* 2:PulseMonitor.c **** PulseMonitor.c 3:PulseMonitor.c **** */ 4:PulseMonitor.c **** 5:PulseMonitor.c **** #include "simpletools.h" 6:PulseMonitor.c **** 7:PulseMonitor.c **** long clocks = 0; 8:PulseMonitor.c **** 9:PulseMonitor.c **** int main() 10:PulseMonitor.c **** { 13 .loc 1 10 0 14 0000 0400FC84 sub sp, #4 15 .LCFI0 16 0004 00003C08 wrlong lr, sp 17 .LCFI1 18 0008 0800FC84 sub sp, #8 19 .LCFI2 11:PulseMonitor.c **** clocks = count(0, 1000); 20 .loc 1 11 0 21 000c 00007C5C mvi r1,#1000 21 E8030000 22 0014 0000FCA0 mov r0, #0 23 0018 00007C5C lcall #_count 23 00000000 24 0020 00007C5C mvi r7,#_clocks 24 00000000 25 0028 00003C08 wrlong r0, r7 12:PulseMonitor.c **** print("%d\n",clocks); 26 .loc 1 12 0 27 002c 00007C5C mvi r7,#.LC0 27 00000000 28 0034 00003C08 wrlong r7, sp 29 0038 0000BCA0 mov r7, sp 30 003c 0400FC80 add r7, #4 31 0040 00003C08 wrlong r0, r7 32 0044 00007C5C lcall #_print 32 00000000 13:PulseMonitor.c **** }... 33 .loc 1 13 0 34 004c 0000FCA0 mov r0, #0 35 0050 0800FC80 add sp, #8 36 0054 0000BC08 rdlong lr, sp 37 0058 0400FC80 add sp, #4 38 005c 0000BCA0 mov pc,lr 39 .LFE1 40 .global _clocks 41 .section .bss 42 .balign 4 43 _clocks 44 0000 00000000 .zero 4 82 .Letext0 83 .file 2 "C:/Users/n/Documents/SimpleIDE/Learn/Simple Libraries/TextDevices/libsimpletext/simpletex DEFINED SYMBOLS C:\Users\n\AppData\Local\Temp\ccIBm3CJ.s:10 .text:00000000 _main C:\Users\n\AppData\Local\Temp\ccIBm3CJ.s:14 .text:00000000 L0 C:\Users\n\AppData\Local\Temp\ccIBm3CJ.s:43 .bss:00000000 _clocks .data:00000000 .LC0 .debug_frame:00000000 .Lframe0 .text:00000000 .LFB1 .debug_abbrev:00000000 .Ldebug_abbrev0 .text:00000000 .Ltext0 .text:00000060 .Letext0 .debug_line:00000000 .Ldebug_line0 .text:00000060 .LFE1 .debug_loc:00000000 .LLST0 .debug_info:00000000 .Ldebug_info0 UNDEFINED SYMBOLS sp lr __LMM_MVI_r1 r0 __LMM_CALL _count __LMM_MVI_r7 r7 _print pc
The C code:
/* PulseMonitor.c */ #include "simpletools.h" long clocks = 0; int main() { clocks = count(0, 1000); print("%d\n",clocks); }
Source
Take a look at line 32. Documentation on `st_pauseTicks` says it defaults to 1/4 second, which would imply that if you call `count(0, 1)`, you should expect to get a return value of 250 for a 1000 baud signal.
0.25 * 1000 = 250 seconds. That will overflow the `tf`.
Are you sure you're not thinking of st_timeout?
st_timeout = 250*st_msTicks; in http://david.zemon.name/PropWare/timeTicks_8c_source.html (Thanks for the link!)
And did I miss something in calculating tf in my head? I don't feel a long should overflow at these values...
Perhaps it is time I scratch together the money for a real scope. I have been investigating a very cheap USB one called the DDS120, and the signal I'm trying to get from it is its Encode clock sent to the ADC. The device is cheap enough that one might leave it in a permanent installation, or upgrade from an RTL-SDR, but it needs new firmware. Three others have started to work on the same project and by now I'm barely keeping up with them.
Thank you very much for your help! I'll study the code you posted in detail. =D
We've had oscilloscope threads here before. There's lots of praise for both Propalyzer and Saleae's Logic line.
