Elf - my RoboPi + Raspberry Pi 2WD robot — Parallax Forums
Bill HenningBill Henning Posts: 6,445
edited 2014-10-23 17:30 in Robotics
I thought I'd take a break from my two large fun projects (HexPi and TBMST) to show you guys Elf - my RoboPi + Raspberry Pi + Magician 2WD based robot:
Right now, Elf also has a breadboard, an HC-SR04 ultrasonic range sensor, an L9110S based motor driver, and two battery packs :)
More details & Photos at my Elf build log at:
http://www.mikronauts.com/robot-zoo/elf-2wd-pi-robot/
Feel free to ask any questions about Elf here!
  • mklrobomklrobo Posts: 420
    edited 2014-07-19 12:23
    :cool: Cool robot! What kind of activities does it do? Does Elf stand for Electronic Life Form?
    edited 2014-07-19 16:20
    Thanks!
    Right now, Elf can run around avoiding obstacles in front of him.
    He is basically my testbed for controlling L9110S motor drivers from RoboPi, and I am working on enhancing the PWM motor API.
    Later, he will get additional sensors (Pi Camera for one) and be able to do more :)
    Electronic Life Form... good one!
    Actually, I am using mythical creature species names for my Pi test bots:
    Sprite - simple bot, without RoboPi, see January 2014 Servo (completed, may be improved in the future)
    http://www.mikronauts.com/robot-zoo/sprite/
    Elf - this bot, RoboPi + Pi - 2WD gear motor, PWM motor control
    http://www.mikronauts.com/robot-zoo/elf-2wd-pi-robot/ (in progress, will be adding camera soon)
    my fun/advanced RoboPi/Pi bot under construction (delayed due to work) is
    HexPi - RoboPi + Pi - 18 servos - most sophisticated
    http://www.mikronauts.com/robot-zoo/hexpi-hexapod-pi-robot/ (delayed due to MG-995 issues)
    And since I really like Parallax's Boe-Bot chassis, I am also making
    PiBoe - RoboPi + Pi - 2 servo drive, small
    http://www.mikronauts.com/robot-zoo/piboe/ (working on it this weekend, planning on adding camera next week)
    Yep, I am working on three different robots concurrently - but they all have RoboPi and Raspberry Pi's in common, and are helping me improve my RoboPi API.
    I strongly suspect HexPi will take a while to complete... ditto with the associated "The Better Mousetrap" servo tester project.
    edited 2014-07-20 15:14
    Awesome projects! I will try to begin one of my own projects too, and probably use your Raspi board in the robot. I have
    to complete my "tricorder" project first, as that is a pivot point for the rest of my projects. :)
    edited 2014-10-22 13:43
    Hi guys,
    I've updated my Elf article - today, I added:
    - wiring info and photos for the L9110S motor driver
    - wiring info and photos for the HC-SR04 range sensor
    - sample Python code for RoboPi controlling the motor driver via PWM and reading the range sensor
    Elf: http://www.mikronauts.com/robot-zoo/elf-2wd-pi-robot/
    RoboPi: www.mikronauts.com/raspberry-pi/robopi/
    Coming (hopefully) Soon: compass, Pi camera and more!
  • WhitWhit Posts: 4,191
    edited 2014-10-22 18:47
    Great info Bill both on Elf and RoboPi - thanks so much for sharing this and in such great detail!
    Thank you Whit!
    I am glad you like Elf & RoboPi.
    I'll keep updating the Elf article as I add features, I am using Elf as the "low cost gear motor + low cost driver" testbed for RoboPi.
    Soon I'll update PiBoe as well... I managed to get him to shrink by making a custom sintra plate to replace the 4"x3" PCB and EZasPi (B), shaving more than an inch off his height! I just need to find time to edit the photos & write up the changes. PiBoe is my "360 servo" testbed for RoboPi.
    I need to order some BEC's and better batteries and resume work on HexPi as well...
    So many bots... so little time... but it IS FUN!
