P8X32A-Q44 Shortage Expected: place your orders - Page 3 — Parallax Forums
13»
    edited 2014-09-16 07:38
    Parallax to the rescue!
    This morning there are:
    1801 TQFP props
    1188 DIP40 props
    in stock at Parallax.com :):):)
    Thanks Ken!
  • jazzedjazzed Posts: 11,803
    edited 2014-09-16 07:42
    Good news :)
    So, now anyone who has an excess of QFP parts for some reason may need a good home for them.
    I still have a few HeckaProp panels for anyone who wants to solder up to 60 propellers on one board. :)
    edited 2014-09-16 08:15
    1801 TQFP props
    1188 DIP40 props
    Thanks Ken!
    +1 Thank you Ken!
    edited 2014-09-17 05:15
    jazzed wrote: »
    Where is Humanoido when you need him?
  • Ken GraceyKen Gracey Posts: 7,418
    edited 2014-09-22 11:59
    I have an update for all customers on the Propeller shortage, as promised a few posts ago.
    The wafers have shipped from Austria Microsystems (in Austria) today to our packaging supplier in Taiwan. This means we'll have packaged chips here in Rocklin around mid-October. We need a week for testing so my most accurate estimate at this time is the third week of October is when we will have both DIP and QFPs available. Current status:
    1,100 DIPs in stock https://www.parallax.com/product/p8x32a-d40
    800 QFPs in stock https://www.parallax.com/product/p8x32a-q44
    Small numbers will trickle into inventory until we have the huge shipment arrive in October. It's possible we won't even run out of inventory and all of this excitement was for nothing. We'll see - I'm just trying to make sure to provide advance notice of problems before they occur.
    edited 2014-09-22 12:25
    Ken,
    Are you telling us that Prop chips are made in Austria? It never occurred to me that they might have chip fabs in Austria.
    edited 2014-09-22 16:24
    Heater. wrote: »
    Ken,
    At present, yes. Propeller 1 is fabricated in Austria by AMS.
    edited 2014-09-22 17:30
    And for those who don't follow mergers and acquisitions, AMS is also the company that bought TAOS, the optoelectronics spin-off from TI whose sensor chips are used in Parallax's TCS3200 color sensor, and the TSL1401 linescan imager -- and probably a few other Parallax offerings that I've lost track of.
    edited 2014-09-22 19:22
    Thanks for your honesty Ken.
    Interesting that the Fab is done in Austria.
    edited 2014-09-24 08:11
    Thanks for the update Ken.
  • ksltdksltd Posts: 163
    edited 2014-10-21 15:28
    I'm a little confused.
    DigiKey's stock on hand for the DIP: 2033 parts, for the QFP: 1022 and for the QFN more than 800.
    Mouser's stock on hand for the DIP: 329 parts, for the QFP: 1516; they don't appear to stock the QFN.
    Element14 is the only vendor running out - but they're prices are obnoxiously high, anyway.
    There doesn't appear to be any shortage.
    What's the scoop?
  • markmark Posts: 253
    edited 2014-10-21 16:34
    Interesting. Has the Prop always been manufactured by AMS? I figured that with the Prop2 fab talk centered around ON-Semi, that it was them who also manufactured the Prop1.
    edited 2014-10-21 16:51
    ksltd wrote: »
    What's the scoop?
    Ken did say there would be a huge shipment in October, (post #66, a month ago). It appears it happened.
    edited 2014-10-21 20:39
    Depending on what huge means. At 7.28mm on a side in 200mm wafers with 80% yield, there's about 380 good die per wafer. A 200mm boat is usually 25 wafers, so that's just shy of 10K good die per boat. Those are pretty conservative numbers - 80% yield is pretty poor for a mature design in 350nm.
    The QFP stock-on-hand has been pretty static for the last two months at around 2K parts in disti. It certainly hasn't gone up as much as "a huge shipment" would suggest and I wouldn't think that a shipment of packaged parts arriving in mid-october wouldn't clear test heads and be shipped to disti yet, anyway. I'd expect the stock on hand would be bottoming out about now but there's really been no motion.
    So the question remains - what's the scoop?
  • VonSzarvasVonSzarvas Posts: 3,605
    edited 2014-10-21 23:42
    ksltd wrote: »
    Makes me think of Pistachio and double choc chip.
    About the stock... I suspect Parallax might keep extra inventory for own products, and they might be "trickling" those out to keep customer stock available until the large shipment clears QC.
    One might call it Propeller QE :)
    edited 2014-10-22 06:15
    ksltd wrote: »
    There's always more than shown on-line because we receive chips in packaged form without test. We stock them in tested and untested formats, with the web only showing what's tested. The yield numbers you provided are an inaccurate guess with actual yield being above 97%.
    edited 2014-10-22 07:07
    No, there was no inaccurate guess. As I said, the 80% was a very conservative estimate chosen specifically to highlight the point that, based on the stock in disti, there has never been a shortage. As someone who bought a considerable amount of inventory based on this thread to cover prototype and production requirements, combined with the dearth of subsequent information, it all starts to seem as if the shortage was about cash flow, not inventory.
    edited 2014-10-22 08:26
    ksltd wrote: »
    We use an Materials Requisition Process, known by the acronym "MRP" in distribution. I imagine you're familiar with MRP and ERP systems from your post above. This system models our projected purchases based on typical demand, lead times for different processes to assemble and test the part, and ultimately suggests purchase order quantities based on incremental quantities, minimum orders, and about six other parameters we identify for each part. The Purchasing Manager reviews the output from the system and approves purchase orders.
    Likely, the shortage we almost experienced probably started with DefCon22. In early June we allocated 16,000 chips towards that project. With a few other unexpected orders the demand exceeded what MRP was projecting.
    Some companies put large customers on lead times and build to order. We generally stock the quantities they want to purchase.
    If you are suggesting that low cash deferred or slowed the placement of more Propeller orders from Parallax to our suppliers that is not the case.
    edited 2014-10-22 15:02
    Unfortunately you cannot win Ken :(
    Thanks for letting us know. Some ordered to cover their requirements and some of us worked out we had sufficient of our own stocks to last, leaving them for others who required them.
    While in the end there was no shortages, I would much rather be warned than all of a sudden find out there was "X" months shortage.
    Some of us are old enough to remember the great shortages of all types of semiconductors years ago - thinks like 2 years lead time were not uncommon to see. Some companies allocated small supplies to their good customers and the rest went without. And then there were the hoarders who bought up big and sold the stock at ransom prices. This happened in particular to DRAM.
  • D.PD.P Posts: 790
    edited 2014-10-22 16:22
    Ken Gracey wrote: »
    Yup, spent 2 years implementing SAP into our procurement, production, retail, wholelsale and web presence. MRP only goes so far and can never account for hugh surges in sales and the wild beast that is human spirit.
  • ManAtWorkManAtWork Posts: 2,237
    edited 2014-11-24 06:54
    No real shortage until now, but stock is becoming low: ~1k P8X32A-Q44, ~5k unmarked Q44
    I just ordered 1000. This time I was really lucky and got 10% discount :-)
    Any news when new stock arrives?
    edited 2014-11-24 07:09
    ManAtWork wrote: »
    You didn't apply the extra 10% Coupon Code? Or did you do a phone order.?
    "If you shop on Parallax.com use this coupon at checkout for 10% off your entire cart - FORUMS2014
    Expires 2014-11-24 at 8am PST"
    edited 2014-11-24 07:39
    10% extra? no, the forum was offline for several days. I only saw a maintenance page.
  • Do we currently have a shortage, again? The new shop system doesn't display the quantity in stock.
  • Hi ManAtWork,
    Ken has detailed the situation here: http://forums.parallax.com/discussion/161692/propeller-1-p8x32a-d40-and-p8x32a-q444-supply-expectations
    In brief, some unexpected large orders drained the immediately available stock, but Parallax have about 2 months supply in reserve and are moving that into the online store over the next week or so.
    Some online distributors also hold stock. And in October, Parallax will be getting the next scheduled bulk shipment from the chip foundary to replenish warehouse supplies.
    If you have any specific urgent requirements, please contact sales@parallax.com. They are ready and able to help !
    Hope this helps!
