It looks like the negative zero is messing things up a bit.
Calculate(constant(pi))rad = 3.1415928 or = $40490FDB, F.Sin(rad) = -0 or = $80000000, F.cos(rad) = -1 or = $BF800000
F32.ATan2(F.Sin(rad), F.Sin(rad)) = -3.1415928 or = $C0490FDB
Calculate(pi)
Calculate(3.132866)
rad = 3.132866 or = $404880E0, F.Sin(rad) = 0.0087259256 or = $3C0EF72F, F.cos(rad) = -0.99996384 or = $BF7FFDA1
F32.ATan2(F.Sin(rad), F.Sin(rad)) = 3.1328666 or = $404880E3
Calculate(3.141593)
rad = 3.141593 or = $40490FDC, F.Sin(rad) = -0 or = $80000000, F.cos(rad) = -1 or = $BF800000
Calculate(3.1415926)
rad = 3.1415928 or = $40490FDB, [COLOR=#ff0000]F.Sin(rad) = -0 or = $80000000[/COLOR], F.cos(rad) = -1 or = $BF800000
Calculate(3.1415925)
Calculate($40490fdd)
rad = 3.1415932 or = $40490FDD, F.Sin(rad) = -0 or = $80000000, F.cos(rad) = -1.0000005 or = $BF800004
Calculate($40490fdc)
Calculate($40490fdb)
Calculate($40490fda)
rad = 3.1415926 or = $40490FDA, F.Sin(rad) = 0 or = $00000000, [COLOR=#ff0000]F.cos(rad) = -1.0000005[/COLOR] or = $BF800004
F32.ATan2(F.Sin(rad), F.Sin(rad)) = 3.1415928 or = $40490FDB
Calculate($c0490fdd)
rad = -3.1415932 or = $C0490FDD, F.Sin(rad) = 0 or = $00000000, F.cos(rad) = -1.0000005 or = $BF800004
Calculate($c0490fdc)
rad = -3.141593 or = $C0490FDC, F.Sin(rad) = 0 or = $00000000, F.cos(rad) = -1 or = $BF800000
Calculate($c0490fdb)
rad = -3.1415928 or = $C0490FDB, F.Sin(rad) = 0 or = $00000000, F.cos(rad) = -1 or = $BF800000
Calculate($c0490fda)
rad = -3.1415926 or = $C0490FDA, F.Sin(rad) = -0 or = $80000000, F.cos(rad) = -1.0000005 or = $BF800004
I was going to suggest using $40490FDA as pi (since it's actually the closest value without going over), but this causes trouble with the cosine method.
Ok
The problem is solved now: Hanno found the error. His compiler used 3.141593, which equates to $40490FDC. He had to change this to $40490FDB.
Thank to all for the support.
In my recent tests, the Prop tool used $40490FDB for pi, I'm not sure this is the best value since as I mentioned above, $40490FDA is the largest approximation to pi without going over the value.
I'm not sure if floating point math on the Prop was ever expected to match the results one gets with a PC. I don't see a big problem with any of this.
Actually it should match pretty closely for most purposes -- the IEEE floating point standard specifies exact results for the basic operations, and things built on top of these (like Sin and Cos) should be able to come up with the same answers, modulo some slight variation in the algorithms used for the trig functions.
The PropGCC floating point libraries have passed a bunch of floating point tests, for both 32 and 64 bit floating point, so if you can switch from Spin to C you might get better results. Writing floating point code in a language that has built-in support is definitely easier (perhaps Spin 2.0 will make floating point more integral to the language).
f32.atan2(f32.sin(Constant(PI)),f32.cos(Constant(PI)))) gives -Pi
Magnetspin
BTW, here's a 32-bit floating point converter I found interesting and helpful.
F32[PATH].Start FloatStr.SetPrecision(8) 'Com.Lock NewLine Com.Str(DEBUG_COM, string("Calculate(constant(pi))")) Newline Calculate(constant(pi)) NewLine Com.Str(DEBUG_COM, string("Calculate(pi)")) Newline Calculate(pi) NewLine Com.Str(DEBUG_COM, string("Calculate(3.132866)")) Newline Calculate(3.132866) NewLine Com.Str(DEBUG_COM, string("Calculate(3.141593)")) Newline Calculate(3.141593) NewLine Com.Str(DEBUG_COM, string("Calculate(3.1415926)")) Newline Calculate(3.1415926) NewLine Com.Str(DEBUG_COM, string("Calculate(3.1415925)")) Newline Calculate(3.1415925) NewLine Com.Str(DEBUG_COM, string("Calculate($40490fdd)")) Newline Calculate($40490fdd) NewLine Com.Str(DEBUG_COM, string("Calculate($40490fdc)")) Newline Calculate($40490fdc) NewLine Com.Str(DEBUG_COM, string("Calculate($40490fdb)")) Newline Calculate($40490fdb) NewLine Com.Str(DEBUG_COM, string("Calculate($40490fda)")) Newline Calculate($40490fda) NewLine Com.Str(DEBUG_COM, string("Calculate($c0490fdd)")) Newline Calculate($c0490fdd) NewLine Com.Str(DEBUG_COM, string("Calculate($c0490fdc)")) Newline Calculate($c0490fdc) NewLine Com.Str(DEBUG_COM, string("Calculate($c0490fdb)")) Newline Calculate($c0490fdb) NewLine Com.Str(DEBUG_COM, string("Calculate($c0490fda)")) Newline Calculate($c0490fda)The method "Calculate" is:
PUB Calculate(rad) | temp0, temp1 Com.Str(DEBUG_COM, string("rad = ")) Com.Str(DEBUG_COM, FloatStr.FloatToString(rad)) Com.Str(DEBUG_COM, string(" or = $")) Com.Hex(DEBUG_COM, rad, 8) temp0 := F32[PATH].Sin(rad) Com.Str(DEBUG_COM, string(", F.Sin(rad) = ")) Com.Str(DEBUG_COM, FloatStr.FloatToString(temp0)) Com.Str(DEBUG_COM, string(" or = $")) Com.Hex(DEBUG_COM, temp0, 8) temp1 := F32[PATH].Cos(rad) Com.Str(DEBUG_COM, string(", F.cos(rad) = ")) Com.Str(DEBUG_COM, FloatStr.FloatToString(temp1)) Com.Str(DEBUG_COM, string(" or = $")) Com.Hex(DEBUG_COM, temp1, 8) NewLine result := F32[PATH].ATan2(temp0, temp1) Com.Str(DEBUG_COM, string("F32.ATan2(F.Sin(rad), F.Sin(rad)) = ")) Com.Str(DEBUG_COM, FloatStr.FloatToString(result)) Com.Str(DEBUG_COM, string(" or = $")) Com.Hex(DEBUG_COM, result, 8) NewLineThe method "NewLine" clears the end of the line and enter a carriage return.
As seen in the output the compiler rounds some of the floating point numbers differently than the floating point objects.
