Water-Activated, Emergency Light
http://www.etoncorp.com/en/productdisplay/blackout-buddy-h2o
Interesting product...
Dip the Blackout Buddy H20 in a small cup of water to activate the battery module and light the way. Simply add water once per day to keep the light shining for up to 72 continuous hours.
The rugged, environment-proof package means you can store it for up to 10 years without degradation.
No...
Good Alkalines have a shelf life of 10 years, and can be used in all kinds of devices.
The Water activated batteries have an achilles heel... A horrendous self-discharge rate as soon as it has been activated.
And some of them can be activated by high air-humidity, so they need to be packaged in airtight boxes.
Once activated, the process can't be stopped, only slowed.
(Which explains the 'up to 72 hours'.)
I bet the water-activated battery is non-replaceable, too...
Looks like a throw-a-way. Not good for environment?
(The salt water recharger is a based on a similar tech as the battery in that LED light.)
I bet that the anode slowly dissolves even if there's no cells in the charger if there's even a hint of moisture left in the system after use.
EDIT: And it seems they don't sell the anodes separately...
